ECM connections...need help
Hey guys when i put in my new memcal I couldn't figure out how to get the four big plugs off. Do they just unclip like you push down on both tabs and pull?? Or is it somthing different. I'm talking about the four big connections that go in to the ECM. Thanx guys.
No no I already changed the memcal and now I just want to put the new ECM in with the memcal but I cant get those connections off.
Ahhhh....I misunderstood. They should just come off. I think they are attached with a little clip thing, like most of the sensor connections. None of my manuals show a good pic or tell how to get them off, they just say "take the plugs out"
Those 4 connectors are somewhat difficult to remove.
You need a small flat screwdrive to push the plastic tab down while pushing it outwards and do the same on the backside of the same connector. Only then you can pull out the connector. Do this on the 3 other connectors.
