bryanjoseph Posted December 20, 2003 Report Posted December 20, 2003 I timed my '91 GTP, an automatic, at about 10.5 sec. from 0-60. Published numbers for a 3.4L GTP with an automatic when new are at 8.5 sec for 0-60. Obviousy you'd expect an engine with 125 000 miles to be a little worn but this seems to be a large loss of power. Besides internal engine wear of piston rings, etc , What other worn engine parts would decrease the performance of an engine? Quote
phantomFE3 Posted December 20, 2003 Report Posted December 20, 2003 valvetrain, all the lifters and springs and the cams and everything will wear out Quote
93GTP Posted December 20, 2003 Report Posted December 20, 2003 -Timing belt wear, knocking out timing. -Bad O2 sensor -Vacuum leaks -Dirty injectors By the way, the stock number is more like 7.5 for 0-60 Quote
cutsup1996 Posted December 20, 2003 Report Posted December 20, 2003 run some topend cleaner, fuel system cleaner, how are plugs and wires? O2 sensor, is CAT good? timing, what octane gas you run, clean IAC too. Quote
whitetrack Posted January 1, 2004 Report Posted January 1, 2004 ... could also be that the catalytic converter is breaking down. When that happens is clogs the pipe and builds up back pressure, reducing performance. Quote
