Andrew T Posted March 31 Report Posted March 31 Have 96 supreme with a bum mono spring. Looking to replace it or put spring/struts in place. I have read about the change to spring struts but finding it difficult to find the part or parts and a how to. The mono leave is difficult to find also it appears. I'm sure this has been addressed here before but I'm new and looking for some definitive suggestions. Thanks Quote
White93z34 Posted March 31 Report Posted March 31 There's a shop in Canada that either still does them or did them. Probably worth a call. https://cvmbirch.ca/ Birchmount springs, I want to say back in the day they sold a bunch of them to various members. Other then that its probably used as the only other option. 94 olds vert 1 Quote
55trucker Posted March 31 Report Posted March 31 For those in the states one doesn't HAVE to approach CMV, for me they're not far away, but keep in mind that the company has changed ownership & the staff now there are not the staff who used to fab these springs 20 + years ago. The last time I spoke with the current owner John Geropolous none of the staff had any experience putting together one of these multi leaf springs to replace the glas leaf. When the original owner Alex Vitanoski & his son left they took the know how with them. But that aside any capable spring shop can fab up a replacement for the glas leaf, all they need is the car, the old spring & do the formula to make a 2 leaf or 3 leaf replacement that will be either a high arc or shallow arc, oem height or custom height depending on what you the owner are looking for. The indepth part is getting either outboard side of the chassis mounting points exactly the same arc so the back end of the car sits even. Because of their lack of knowledge I did not go to them, instead I used a spring shop close to home to fab what is currently under the car. Quote
Andrew T Posted March 31 Author Report Posted March 31 Anyone know of the mentioned kit or conversation to coilovers? Quote
White93z34 Posted March 31 Report Posted March 31 All I remember about that was at one point people figured out how to build rear coil overs out of mostly off the shelf parts. There was always plenty of discussion around ride quality, and if the stock upper mounts could take the added forces, but to my knowledge no one ever had issues with that part of it. I was never into lowering my car so I can't speak to it, but I see no reason why it couldn't be used to bring the car back up to factory height as well. It might take a heap of searching old threads on here but the information is likely still around from then. Quote
Andrew T Posted April 1 Author Report Posted April 1 White.. This is what I'm learning but as you mentioned, it appears it would be a (very?) deep dive and likely time consuming endeavor. I'm exploring a replacement but they are scarce. It would cool to construct the coil strut and install but there is just no enough info to feel comfortable attending it. Thanks for the information and insight. Quote
55trucker Posted April 1 Report Posted April 1 (edited) You can look thru this old posting from 2007, there still may be some useful links in there...... the last member I can remember who did coilovers was Imp558, that was near 8 years ago.... or this one.... Edited April 1 by 55trucker pwmin 1 Quote
Andrew T Posted April 1 Author Report Posted April 1 55 .... Thanks! Def the most and most consice information I've read so far. Some of the links are dead ends (of course, there pretty old) unfortunately but I'm going to attempt to connect some of the businesses and I may have a lead on a spring found on ebay. Thanks again Quote
Andrew T Posted April 4 Author Report Posted April 4 Finding a spring (and a shop interested in a replacement) is proving difficult. Anyone know of a swap that is the complete spring and strut from another W body or GM car that could 'bolt in'? Quote
55trucker Posted April 5 Report Posted April 5 20 hours ago, Andrew T said: Finding a spring (and a shop interested in a replacement) is proving difficult. Anyone know of a swap that is the complete spring and strut from another W body or GM car that could 'bolt in'? Where do you live & what sort of response from the shops contacted are you getting? Quote
Andrew T Posted April 5 Author Report Posted April 5 Not far south of Albany NY. Local junkyards have nothing and few suggestions. The spring shops say 'fiberglass, we don't do that' and show no interest in helping out further. Found on in Kentucky, place wants just shy of $400 (350 shipping!). I'd just put in spring struts if knew what exactly to get, I'm reluctant to experiment as that may just end up with a bunch of parts and no money lol. Appreciate the reply Quote
55trucker Posted April 6 Report Posted April 6 Well, a spring shop will only deal in steel items, they can't fab a glas item, this isn't rocket science, any shop can do the job, they just have to show the determination to take on the task. The glas spring is a parabolic design (thicker in the centre, thinner at the ends, making one in a steel configuration is a no-brainer as multi leaf springs are the same sort of design, One selects the single width of each leaf & the thickness to get the wanted spring rate & load rate, It involves cutting the blanks to the required length to make the stack, because the original is a transverse single spring the time consuming part of the job is the mechanic having to arc each leaf individually & get them near perfect in their arc so that each side off centre is near identical & lets the car sit perfectly level from side to side. Quote
Andrew T Posted April 7 Author Report Posted April 7 Agreed. The unwillingness is the problem. It's unfortunate, the car is an otherwise very serviceable vehicle. At this point I'm at a loss for a solution. Quote
55trucker Posted April 7 Report Posted April 7 (edited) About the most direct approach would be to make use of car-part.com, select a Grand Prix, the results should cover all years using the fiberglas rear spring, you'll want one that matches your cars suspension options. Car-part refers to the rear spring as.....*leaf spring, rear* do a *north east* search.....the most expensive displayed was $180...the cheapest was $35 one location in Syracuse *Central auto recycling* came back with a spring at $100 https://car-part.com/ Edited April 7 by 55trucker Quote
White93z34 Posted April 7 Report Posted April 7 generally speaking I would go after a earlier car 88-91-ish the earlier springs seemed to not sag as badly Quote
Andrew T Posted April 7 Author Report Posted April 7 55 .... Thank you! Great information. White ....very helpful also! Appreciate it. Gives me hope lol Quote
Andrew T Posted April 9 Author Report Posted April 9 Thank you all for the suggestions and helpful information. Found a spring at a reasonable price with reasonable shipping. Shout out to 55... for the part source. After arrival and install I'll check in again. Quote
55trucker Posted April 9 Report Posted April 9 20 minutes ago, Andrew T said: Thank you all for the suggestions and helpful information. Found a spring at a reasonable price with reasonable shipping. Shout out to 55... for the part source. After arrival and install I'll check in again. You'll probably need some instruction on how to get the spring in & out....without the *compressor* it is a bit of a task, one has to disassemble the rear suspension to get the old one out & the replacement in. Quote
Andrew T Posted April 9 Author Report Posted April 9 SB, great vid and I'm sure very helpful to pursue that avenue . Do you have part numbers? 55.... I'm having a trusted shop do the work as I don't have the equipment. They are experienced mechanics and I'm confident can handle the job. Thanks tho Quote
