darklotus42 Posted Thursday at 03:31 AM Report Posted Thursday at 03:31 AM Has anyone ever tried to swap miniquad headlights from a GP to a CS? I got in a bit of a fender bender and now all my lights are smashed to bits. I can't seem to find a CS header panel to save my life but the yard here has a couple GPs but idk if I could Frankenstein something together. Lmk any thoughts. Quote
jiggity76 Posted Thursday at 03:50 AM Report Posted Thursday at 03:50 AM The header panel from a Grand Prix coupe is very different compared to a CS coupe. The headlamps will be the same though. 94 olds vert 1 Quote
tornado_735 Posted 22 hours ago Report Posted 22 hours ago (edited) Try finding a salvage yard Cutlass on http://www.car-part.com if you haven't already. Edited 22 hours ago by tornado_735 Quote
ManicMechanic Posted 21 hours ago Report Posted 21 hours ago (edited) 18 minutes ago, tornado_735 said: Try finding a salvage yard Cutlass on http://www.car-part.com if you haven't already. That's where I found the one in Hearne in his other thread. I work for car-part. Edited 21 hours ago by ManicMechanic tornado_735 1 Quote
tornado_735 Posted 21 hours ago Report Posted 21 hours ago 26 minutes ago, ManicMechanic said: That's where I found the one in Hearne in his other thread. I work for car-part. No shit!! It's my go-to. I love car-part. Quote
ManicMechanic Posted 20 hours ago Report Posted 20 hours ago 36 minutes ago, tornado_735 said: No shit!! It's my go-to. I love car-part. They suck to work for, but I make my own hours and get to see rare stuff that comes in locally. pwmin and jiggity76 2 Quote
55trucker Posted 9 hours ago Report Posted 9 hours ago On 1/15/2025 at 10:50 PM, jiggity76 said: The header panel from a Grand Prix coupe is very different compared to a CS coupe. The headlamps will be the same though. Ok, clue me in, how is the stamping for the rad header different for a 1st gen GP vs the Cutlass? Quote
94 olds vert Posted 8 hours ago Report Posted 8 hours ago (edited) 1992 Grand prix GTP header panel for the headlights. #15 1992 Cutlass Supreme SL head panels for the headlights. #13 At one point in time I had both of these and they are different. I'm pretty sure they could be interchanged it might take a bit of work due to mounting points being different on the rad support. I have no idea about the bumpers or how the lights would align. The rad support is nearly the same. 1992 GP rad support 1992 Cutlass Supreme rad support Note the different part numbers. The work needed to do this would probably require drilling, welding, and painting. Edited 8 hours ago by 94 olds vert hopefully that's easier to understand jiggity76 1 Quote
55trucker Posted 8 hours ago Report Posted 8 hours ago Ok, the fog is clearing, when the OP used the term *header panel* the rad header IS the header panel. The headlamp mounting panel is all bolt-on plastic. 94 olds vert 1 Quote
jiggity76 Posted 23 minutes ago Report Posted 23 minutes ago (edited) 7 hours ago, 55trucker said: Ok, the fog is clearing, when the OP used the term *header panel* the rad header IS the header panel. The headlamp mounting panel is all bolt-on plastic. Thank you for 94 vert showing the differences. With me owning an STE and a Cutlass Supreme coupe, I know there are differences between those for the obvious reasons. When I had my 93 GTP parts car, I just remember that the header panel was a lot different compared to my 91 Cutlass coupe. Just guessing here but I'm assuming the rad supports are all the same between W body's...it's the header panels that are unique between let's say a Regal or Prix, etc. 55...maybe I have the terminology mixed up? For me, the header panel is the plastic or whatever material it is that mounts the grills, headlamps, turn signals, etc TO the radiator support. Edited 19 minutes ago by jiggity76 94 olds vert 1 Quote
94 olds vert Posted 18 minutes ago Report Posted 18 minutes ago 2 minutes ago, jiggity76 said: Thank you for 94 vert showing the differences. With me owning an STE and a Cutlass Supreme coupe, I know there are differences between those for the obvious reasons. When I had my 93 GTP parts car, I just remember that the header panel was a lot different compared to my 91 Cutlass coupe. Just guessing here but I'm assuming the rad supports are all the same between W body's...it's the header panels that are unique between let's say a Regal or Prix, etc. Not sure why the different part numbers for the rad support. The only thing I can think of is different mounting locations. That could easily be taken care of. The rad support will interchange. Quote
darklotus42 Posted 15 minutes ago Author Report Posted 15 minutes ago How would you replace a rad support? Looks like it's spot welded Quote
