Human Posted Sunday at 08:14 PM Report Share Posted Sunday at 08:14 PM So, yesterday was a lovely afternoon in the mid-70s, perfect convertible weather, so I took the 'vert out to run a couple of errands. Each time I parked, I put the top back up so I could lock it up. Leaving my first stop, I put the top down, and when it reached 'bottom', it gave a loud 'POP!' When I got to my next stop, I tried to put the top back up and it only tried to go up on one side. I'm guessing a cable broke or popped loose, but I just don't know for sure. I'm also not sure how to get the top back up so I can eyeball the mechanism and maybe see what's what. Quote Link to comment Share on other sites More sharing options...
94 olds vert Posted Sunday at 10:06 PM Report Share Posted Sunday at 10:06 PM (edited) Sounds like something broke. Hard to say what exactly without doing a visual inspection. You should be able to manually lift the top up slowly without doing any damage to the top itself. Then you will need to inspect for anything that broke. I can't find the post, but years ago someone had a similar issue and it was a bracket that cracked. The top was only lifting on one side. I don't remember specifics as that was likely 10+ years ago. Edited Sunday at 10:07 PM by 94 olds vert Quote Link to comment Share on other sites More sharing options...
