brian89gp Posted December 17, 2003 Report Posted December 17, 2003 I was thinking it is a GM only part. Quote
mfewtrail Posted December 17, 2003 Report Posted December 17, 2003 according to a manual(it's old so I'm not sure if it's accurate...the # works on GMpartsdirect.com though), the trans mount part # for the standard transmission is 14088170 ...can someone confirm that this is infact the trans mount Davis needs? Quote
Guest TurboSedan Posted December 18, 2003 Report Posted December 18, 2003 my new lower trans mount was $50 something from the GM dealership. i'd varify the part # but my receipt is down in Laramie right now, about 4hrs from me :? the dealership had no problem finding and ordering the correct part for me tho. joshua Quote
5speedz34 Posted December 18, 2003 Report Posted December 18, 2003 my new lower trans mount was $50 something from the GM dealership. i'd varify the part # but my receipt is down in Laramie right now, about 4hrs from me the dealership had no problem finding and ordering the correct part for me tho. joshua Yeah, same with me I ordered mine from GMparts direct, and it was like 40 I think. Quote
5speedz34 Posted December 18, 2003 Report Posted December 18, 2003 If its the same as the 284's I could get u a pic but I would need someone to tell me if it is or if it isn't. Quote
Guest TurboSedan Posted December 18, 2003 Report Posted December 18, 2003 i don't have a pic of one available, but the Getrag 282 mount has studs that point straight down into the subframe. i'm pretty sure the 4T60 has studs that point towards the drivers side of the car. i remember the 4T60 mount bolts to a big bracket which then bolts to the subframe. the mounts are similar tho. joshua Quote
