lowering 97 cutlass supreme
Go to solution Solved by 97cutty,
so I’m kinda new to the forum and was wondering if anyone’s lowered their olds cutlass and what setup they used because I’m not finding much
Edited by 97cutty
We have a stickied thread in the suspension subforum. It literally is titled How to lower a W-body.
already looked at that, the coilovers website no longer works it seems
Front - either build your own coilovers, find some of the unobtanium 95-99 lumina/monte springs, or cut a coil off the front factory spring
rear - build your own coilovers, or call birchmount springs in burlington Ontario and se if they will build you a new spring like they did 15-20 yrs ago.
It's a tough go now to lower the car these days :(
Wild Guess with no evidence:  The car is now about 27 years old.  The springs are probably originals.  Therefore, it's not unreasonable to assume that the springs have fatigued.  The car IS lower.
Measure ride-height the way GM intends.  I bet you find the vehicle has settled.
  • Solution
I’m trying to lower it about 2-3 inches
Edited by 97cutty
Making some Frankenstein coilovers is probably the easiest way to do it, but your car will handle worse because of it. That leaf spring in the back gives the car some extra stability that allows it to run a smaller sway bar. Keep that in mind if you want to do any sort of spirited driving with the car.
  • Like 2
IS there a leaf spring in back?  I thought the newer W-bodies had coils.  Perhaps I'm wrong.
Dropping the car 3 inches is likely to make the car very evil handling, especially after hitting a bump or four.  What you'd gain in reduced center-of-gravity is lost with reduced suspension travel and compromised control-arm angles and alignment angles.
All the other W bodies went to the rear coil over design except the Cutlass, perhaps that final 4 door sedan model had it but IIRC wasnt a W body.
Some Ws like my 1994 Cutlass doesnt even have a sway bar but uses figure 8 looking rubber parts I forgot the name of. To install a sway bar on a car without one from factory (which will have to be done to lower the car) one will need a pair of brackets only found in the salvage yards.
Might I suggest starting a intro thread and post some pics of your ride?
17 hours ago, 97cutty said:
I’m trying to lower it about 3 inches
That's a quite a lot,
why would you want to go that low?
as stated that much drop will ruin the geometry of the front suspension at the ball joint. You will lose any or all of the *neutral* geometry of the lower control arms.
Mb more it would more be like 1-2 with the new wheels and tires
yea sure I’ve been thinking ab that, she’s pretty rough rn but im going to be restoring her back to how my uncle had it back in the early 00s but also wanting to do some other things to make it look the best it can
So would I have to run a bigger sway bar after removing the leaf if I were to go that route? Seems like a custom setup it the move
I'd definitely recommend it or your car will be very prone to understeering. You can fit the sway bar from a gen 1.5 Monte Carlo in a 1st gen but its like a half inch wider so youll have to make a slot in the bushing to fit it or make new bracket mounts. Does the car have FE1 or FE3 suspension? FE3 gives you the largest 1st gen rear sway bar but its still pretty small.
I’d say probably the fe1, I think the fe3 was only for convertibles but I should be able to make the 1.5 gen monte sway bar work
FE3 should've been available as an option for any variety of Cutlass, as far as I'm aware FE1 is more common for Sedans and FE3 is more common for Coupes. '97 was a weird year though since they were phasing out the Cutlass Supreme, you can check by finding the sticker in the trunk with all the RPO codes. It looks something like this.
Edited by Amanita
Can’t find a sticker like that in the trunk there’s one for the tires and towing capacity. Is there anyway I can tell by looking at the suspension itself ?
you have any experience with making coilovers for these? parts, specs etc.
My car is on the other side of the state currently so I can't confirm this but I think it's under the cover for the spare tire. If it isn't there, @ManicMechanic should be able to tell you what options you have with the VIN. Checking the diameter of the rear sway bar with calipers might be the easiest way to know if you have FE1 or FE3 otherwise. I think FE3 rear sway bars are 12mm, I do not know what size FE1 sway bars are, or if first gens even have them at all. Second gen FE1 cars have massive sway bars in comparison, around 20mm in diameter. My '96 Grand Prix has FE3 suspension and it is pretty nimble, my '98 Grand Prix has FE1 and it is really prone to understeer.
I do not, there's a thread somewhere on this site that talks about making them but it has been years since I read through it. I'll look for it tomorrow when I get a chance.
Edited by Amanita
Ok I’ll need to look into my suspension more after I get out of school to see, really appreciate it lmk if you find anything thank you for the info.
Edited by 97cutty
Found the posts, and the member who wrote them up is still active. @MemphisMan
@Psych0matt is another active member with a lowered car.
I wanted to lower my car when I first got it but I ended up just replacing all the worn components and installing front and rear strut bars.
My car was super low when I first lowered it, miscalculated the springs in the front (I think) and had to order taller ones, at its tallest it was still rubbing every turn or bump lol but mine are basically regular coilovers made from (at least at the time) ready available parts aside from the mounts, which were custom made by Bxx (who isn’t active here any more but I still talk to him). If you look through my build thread I think most of the info is still there aside from photobucket and th holding my pictures hostage, but it wasn’t too hard conceptually. I did raise it up I think two years ago because I went slightly wider and taller tires so it’s not quite as slammed, but it’s rare I rub.
for simplicity’s sake I can’t say I’d shy away from cutting coils if your goal is lowering, I’ve heard it doesn’t affect the ride too badly.
Looked more and found the sticker, its the fe1 suspension
You'll probably want to find FE3 parts first before you even think of switching to coilovers, the 1st gen w-body chassis is already like a wet noodle with the FE1 suspension and getting rid of the monoleaf will make it worse.
I don't know if the leaf is different but you'll want the sway bars and front coil springs. The strut bar from a Cutlass Supreme convertible won't hurt either.
I feel like I should also mention that not many people have attempted to remove the monoleaf, it's apparently a massive pain in the ass.
Edited by Amanita
How have the mounts held up? I remember reading a post from over a decade ago where somebody was concerned that custom mounts would wreck the strut towers.
Edited by Amanita
