1992 Lumina code 33
My car stalled at a light and started back up. I plugged up my code reader and got code 13. So I replaced the 02 sensor a week later it stalled again and wouldn't start. Ended up being a blown 10amp dis fuse so I replaced ICM and Coils, IAC, fuel pump ,filter and tank and changed the plenum gaskets. I Started the car afterwards and now  you can hear it surge it the engine light came on and I got code 33 it won't idle unless I tap the gas pedal. The only vacuum line that is broke is the one that goes to the a/c check valve. Does that hose effect driveability? or just the hvac ?
Edited by 90sEraWhips
A quick google search for code 33 comes up with MAP sensor. That could be related to your vacuum leak. I would fix the hose and see if the issue goes away. Your symptoms sound like a typical vacuum leak.
  • Like 1
Not sure why you would go to all of this *effort* for a code 12?
A failed o2 sensor will do nothing more than prevent the fuel system from going closed loop.
  • Like 2
I swapped the Map sensor with two more I had laying around that I pulled from the junkyard the code and rough idle still remains. There's a High wine sound coming from the plenum.
"12" is normal when the engine isn't running.  It's telling you that the distributor isn't turning--which is what happens when the engine doesn't run.
A failed O2 sensor CAN do more than "prevent closed-loop".   It can send false information to the computer generally leading to poor fuel economy and/or poor driveability while in closed-loop.
Absolutely, find and fix the vacuum leak(s).
  • Like 1
Noooo, a *failed* o2 sensor will prevent the ECM/fuel system from going into closed loop, a *lazy* o2 sensor can cause the ECM to repeatedly enter & exit closed loop upsetting the fuel handling and any other device that operates when the system is in closed loop.
  • Like 1
This. There is likely a vacuum leak someplace.
  • Like 1
We're debating over the definition of "failed".
If an O2 sensor isn't sending CORRECT information, I say it's failed.  Lazy = failed.
If an O2 sensor isn't sending ANY information, you say it's failed.
My 88 K1500 would set a "lean" code at highway speed.  I had adequate rich/lean indication up to about 55--65 mph depending on load/wind direction.  Good cross-counts at idle and off-idle, cross-counts reducing as the speed increased.  I went nuts on and off for two years trying to figure-out why the truck went lean on the highway.  Fuel pressure was good, AIR pump diverted to the air cleaner in closed-loop...and stayed there exactly as designed.  Intake gaskets not leaking, no sign of vacuum leaks anywhere.
In desperation, I pulled out the O2 sensor, replaced it with a fresh one.  About the same cross-counts at idle and off-idle...but it didn't go lean at higher speed.  No more lean codes.  Problem solved from that point on.  To me, that's a failed O2 sensor.  To my shame, I screwed-around now and again for two years playing with injector cleaning, fuel pressure, and re-running all sorts of tests on the emissions controls and ignition system because I didn't pitch a (at that time) $13 one-wire O2 sensor in the trash.
My experience is that a failed O2 sensor will generally report false-lean conditions, driving the computer into rich-command, affecting fuel economy and potentially driveability.  I have not seen an O2 sensor fail and deliver rich signal, driving the computer into lean command...but I suppose it could happen.
Edited by Schurkey
  • Like 1
Fixed broken a/c vaccum hose and now the car idles and drives. But now I can hear the injector ticking I know some say this is normal but before today I've never heard it tick. Also a spark plug wire was shaking, when I touched it you can feel a tap. I swapped wires it still did this until I removed the plug and reinstalled it.
