KevenP Posted June 18 Report Share Posted June 18 Shop cannot remove the sensor and won't remove the exhaust manifold for fear of broken studs. Why can't the sensor be moved 'down stream' 8 inches or so? Leave the old one in place and weld in a new bung? Thoughts? Quote Link to comment Share on other sites More sharing options...
Schurkey Posted June 19 Report Share Posted June 19 11 hours ago, KevenP said: Shop cannot remove the sensor and won't remove the exhaust manifold for fear of broken studs. Why can't the sensor be moved 'down stream' 8 inches or so? Leave the old one in place and weld in a new bung? You need a different shop. They're not trying hard enough. Moving the sensor downstream will reduce the exhaust heat warming the sensor. But 8" shouldn't make so much difference that sensor operation would be affected. Bigger problem will be finding out if the exhaust pipe is structurally sound enough to get a bung welded-in; and getting the welding equipment in place to get a leak-free weld. And of course, you need to assure that you have enough harness length, and that the harness won't rub or burn on anything even when the engine moves around on the mounts. I dealt with a Dodge Charger (Hemi) that "the shop" couldn't remove the O2 sensor, left exhaust manifold. Yes, it was a challenge, and it took both of us pushing on a 4-foot lever to pop the sensor loose. Once it broke free, it unscrewed like it had never been stuck to begin with. Generally the threads are damaged, but not this one. Quote Link to comment Share on other sites More sharing options...
KevenP Posted June 19 Author Report Share Posted June 19 Thanks. They got the sensor to move but he said it was 'pulling threads'. I'll have a look at the down pipe. Quote Link to comment Share on other sites More sharing options...
jiggity76 Posted June 19 Report Share Posted June 19 I'm guessing this is an older W? I know the newer ones from 94-96/97 have 2 sensors. One upstream...one down. Quote Link to comment Share on other sites More sharing options...
KevenP Posted June 19 Author Report Share Posted June 19 1 hour ago, jiggity76 said: I'm guessing this is an older W? I know the newer ones from 94-96/97 have 2 sensors. One upstream...one down. '02 GP 3.1 Quote Link to comment Share on other sites More sharing options...
jiggity76 Posted June 19 Report Share Posted June 19 5 minutes ago, KevenP said: '02 GP 3.1 Gotcha. That makes sense then. Quote Link to comment Share on other sites More sharing options...
