1994 Cutlass Supreme - Door Lock Receiver Replacement
I finally got around to replacing my dead power door lock receiver. This is a real stinker of a job, there is a myriad of parts you have to remove enroute to getting at the small black box receiver which (on the coupes) is located next to the rear passengers side speaker behind the rear seatback. And you risk breaking any of them along the way. The manual advised that either the upper passengers side or the upper drivers side plastic trim that goes along the rear windows up the C pillar needs to be removed. Well, no way was I going to do that. I managed to get the rear seat to rear window trim panel off without removing those pieces. That was a bit of good luck, I guess.
IMHO this was a ridiculous place to put this receiver. I decided to relocate the box to rest on top of the inner fender well in the trunk, using some gorilla tape to hold it on. All covered up by the interior trunk carpet. There is plenty of wire to make this happen, no cutting/splicing needed. Now, if that receiver croaks, this will be a 10 minute fix instead of a 3 hour headache. The only thing I broke was one push pin clip, and I am having a heck of a time finding even that. I programmed the transmitters and all is working just fine, mission accomplished.
