gbabione Posted February 20, 2024 Report Posted February 20, 2024 Hello everyone, I'm new to the forum. I have a 2004 Monte Carlo ss. My windshield washer fluid pump is not working. I tried a new pump and multi-switch. Which wire is the ground in the pump connector? I want to see if it's a ground problem. Any other ideas? Quote
Schurkey Posted February 21, 2024 Report Posted February 21, 2024 My much-older Lumina ('92) had a dead washer pump. No voltage to the pump, fuses and other wiring seemed OK. Discovered that the electrical signal to turn the washer pump "on" went through the wiper motor circuit board. The wiper motor board had a fault. And no replacement circuit boards available. Had to scavenge parts from the Treasure Yard. Things may be different, your vehicle is way newer than mine. Verify with the service manual set for your vehicle. Quote
