olds65 Posted September 9, 2023 Report Posted September 9, 2023 Hi guys, I am having a problem with my driver's side window on my '92 convertible. The glass is crooked when I put it all the way up to where the side along the pillar goes up further than it is supposed to. When I close the door the glass is over the convertible top as opposed to under it and along the seal where it should be. If I press down on the rear part of the glass along the pillar side while I am rolling it up it will sit flush where it is supposed to be. I took the door panel off and inspected the regulator and window tracks. Nothing looks to be broken/bent or out of adjustment but there appears to be some sort of play within the components. Hoping I can get some help on where to go from here to get this fixed. Thank you! Quote
