rich_e777 Posted June 23, 2023 Report Posted June 23, 2023 (edited) Alright here she is, the 1989 Pontiac "2000 Le" from Trenton. For some reason that was what the auction lot labeled it as. I had a 3rd party inspector check it out and run the VIN prior to bidding. It was a one owner car from NJ until it went to the auction lot, a slight front end collision a few years ago that set its title into the salvage category. That had to have been repaired out of pocket and when the car was repainted as theres obvious overspray and some peeling around trim. Theres some slight scratches here and there as one would expect but over all it looks amazing for how old it is. 1st pic on the truck when it arrived, It didnt start at first so we pushed it off the trailer and into the driveway, the brakes worked great and the valence only suffered a little. It seemed to have a lot of odd electrical problems and wouldnt crank at all. Thinking it was the aftermarket alarm I went to pull the battery out so I could unplug the damn horn and saw it was from 2011. A new battery had the engine fired right up and I drove it around the block a few times then topped the tank off at the ethanol free place. ...TBC Edited June 23, 2023 by rich_e777 pwmin, Jaywags, primergray and 3 others 2 4 Quote
rich_e777 Posted June 23, 2023 Author Report Posted June 23, 2023 (edited) Driving it around it handles great, a little stiff due to just being worn out. The steering takes some effort but theres no whining coming from the pump. It brakes pretty good for what it is but its quirky I guess is about the right word to describe it. Spongey yet firm and responsive. Sounds real nice on the backroad straights yet when I got it back to the driveway the transmission gave a nice little kick when going into reverse. Probably because of this getting it off the trailer. I could also use a replacement grille insert and Ill post in the wanted section unless someone sees this here and has one. Edited June 23, 2023 by rich_e777 primergray, Ramblin Garage, 94 olds vert and 2 others 3 2 Quote
94 olds vert Posted June 23, 2023 Report Posted June 23, 2023 Glad you got this TGP! It is really clean looking. I'll take a look for a grill. I used to have one. Psych0matt and rich_e777 1 1 Quote
rich_e777 Posted June 24, 2023 Author Report Posted June 24, 2023 `89 Manual and Turbo supplement ordered, better to have on hand just in case. I went to change the oil and its already done, but the trans fluid is definitely old and sort of burnt. Noticed alot of new looking exhaust work done after the turbo and extra heat shielding around the master cylinder that looks newer than other parts. I`d really like to talk to the PO and get the back ground story, this was no doubt a cared for car. All the rubber seals and trim are nice and new looking too, its in really amazing shape. I did find some rust at the end of the front wheel well as it becomes the rocker panels, but I dont think its so bad its structural. You`d never see it unless you reached underneath and felt it. SuperBuick and primergray 2 Quote
rich_e777 Posted July 3, 2023 Author Report Posted July 3, 2023 Went out on a long test run through the neighborhood backroads and man what a car! I had to put some 1x4s down at the end of the driveway to keep from scraping the road. Also had a near panic moment coming across some new speed bumps. I recall seeing the lowered cars hit the bumps diagonally and that seemed to work just fine. To much traffic on the main roads and even on the backroads to get into the pedal though, plus the no tag thing... Bake82, Amanita, 94CSC and 4 others 7 Quote
rich_e777 Posted July 17, 2023 Author Report Posted July 17, 2023 Antique Plates now, went on a decent little trip to Best Buy and it runs and drives just fine. It didnt want to start up afterwards though, everything had power but no cranking at all just a relay clicking. The 3rd try it fired right up though. Took the interstate back and man it just goes. Maybe because I`m used to drive big lumbering slow things, I didnt realize i was around 80-85mph by the end of the on ramp. Even better it just sips on the gas and feels faster that a 2nd gen GTP with the L67 that chugged the premium. I thought the fuel gauge was broken! Taking it to my 1st car show next Saturday for Cars and Coffee, Jiggity`s letting me borrow a grill insert(Thanks again man) Any ideas on how to go about finding the PO? This was a really cared for car that I`m sure they`d want to know what happened to it. pwmin and jman093 1 1 Quote
jman093 Posted July 18, 2023 Report Posted July 18, 2023 9 hours ago, rich_e777 said: Antique Plates now, went on a decent little trip to Best Buy and it runs and drives just fine. It didnt want to start up afterwards though, everything had power but no cranking at all just a relay clicking. The 3rd try it fired right up though. Took the interstate back and man it just goes. Maybe because I`m used to drive big lumbering slow things, I didnt realize i was around 80-85mph by the end of the on ramp. Even better it just sips on the gas and feels faster that a 2nd gen GTP with the L67 that chugged the premium. I thought the fuel gauge was broken! Taking it to my 1st car show next Saturday for Cars and Coffee, Jiggity`s letting me borrow a grill insert(Thanks again man) Any ideas on how to go about finding the PO? This was a really cared for car that I`m sure they`d want to know what happened to it. Having owned 3 TGP's, they will fool you into thinking they are sipping gas. The gas gauge on them stays high forever before finally plummeting. A 1/2 tank on the gauge is more like 1/4 in reality. And by 1/4 tank on the gauge, you'd best be looking for fuel soon. All mine have gotten very low 20s mpg mixed driving on premium. Definitely lower than I've gotten out of 3800s and even lower than both of my LQ1 cars. Nice looking car too, btw. Congrats. rich_e777 1 Quote
rich_e777 Posted August 6, 2023 Author Report Posted August 6, 2023 (edited) Finally had the chance to pull the wheels off and creep around underneath. Not too bad, everything rubber that wears out is pretty much worn out and surface rusted. The calipers were replaced not too long ago with pads and rotors but they were not the coated brand and have rusted over. The rust behind the front wheels doesnt seem to go back to much but I need to get the rocker panel trim off to see for sure. Motor and trans mounts are shot though so I`m not driving it to much until all those are replaced to help preserve the special tires. Those things are pricey so I`m happy to have some good ones that came with it. It needs some work but not a huge investment and will make a great show car, not necessarily for me either. I dont have it "For Sale" officially but would entertain offers before I get too attached to it and want $12,000 for just the wheels. Edited August 6, 2023 by rich_e777 94 olds vert, primergray, pwmin and 1 other 4 Quote
rich_e777 Posted August 19, 2023 Author Report Posted August 19, 2023 Engine mounts replaced with solid parts. 8/18 Quote
rich_e777 Posted September 5, 2023 Author Report Posted September 5, 2023 Discovered the trans modulator vacuum line open to the HVAC ball thats missing. Possible it was lost in the front end collision and never replaced. Some expert just put a bolt in the old crumbling line and called it fixed. I`ll steal the one off the Vert for now, its not a parts car though. Just a reminder to myself to put it back on when I`m reading this in the future. I also have a little oil residue that builds up around the turbo piping and some of the turbine blades look a little burned. Is this an indicator that its about time to have it rebuilt/replaced? Quote
Bake82 Posted September 6, 2023 Report Posted September 6, 2023 On 9/5/2023 at 9:27 AM, rich_e777 said: Discovered the trans modulator vacuum line open to the HVAC ball thats missing. Possible it was lost in the front end collision and never replaced. Some expert just put a bolt in the old crumbling line and called it fixed. I`ll steal the one off the Vert for now, its not a parts car though. Just a reminder to myself to put it back on when I`m reading this in the future. I also have a little oil residue that builds up around the turbo piping and some of the turbine blades look a little burned. Is this an indicator that its about time to have it rebuilt/replaced? First thing I’d do is replace the turbo oil drain line. They were notorious for collapsing and causing issues. rich_e777 1 Quote
rich_e777 Posted November 26, 2023 Author Report Posted November 26, 2023 Discovered my rear jounce bumpers have the consistency of government cheese and coming apart. Most if not all associated bushings underneath are in need of replacement and heavy surface rust on most metal components. So looking at a full suspension rebuild both front and back. The question is to go coil over in the back or stick to factory replacement? 94 olds vert and Mach 5 2 Quote
55trucker Posted November 27, 2023 Report Posted November 27, 2023 Being an N.J. vehicle I'm not surprised to hear about the suspension rot. What sort of condition are the brake lines to the rear in? The car belongs to you, it's your call if you choose to install coilovers, I'd be looking closely at the condition of the rear shock towers to see if they can carry the weight of the car......... seeing as they were never intended to. The car doesn't appear to be *sagging*, if you wanted to keep the car at its present ride height then you could make use of the springs presently under the car, if you decided to *drop* the height then you are looking for lowering coil springs for the front & a custom rear leaf for the rear. Replacement lateral arm bushings are available, entire rear trailing arms also available as well, *assuming* your present lateral arms are still in a healthy state that you can press out the old & in with the new. I earlier this year went thru an entire front & rear rebuild, the route I took was *unconventional*, but it gave me what I wanted from the suspension. rich_e777 1 Quote
pwmin Posted November 27, 2023 Report Posted November 27, 2023 I would go coilover, but again, make sure there is no rot in the strut towers. You can also get new trailing arm mounts (I think). rich_e777 1 Quote
rich_e777 Posted November 28, 2023 Author Report Posted November 28, 2023 Fortunately i've not found any body rust around the rear suspension, just the replaceable parts like the lateral links and trailing arms are crispy. Fuel and brake lines don't inspire confidence either now that I`m under here. I never thought about the strut towers not designed to hold the weight, I`ll keep it close to factory with modded 2gen links and maybe thicker sway bars only. I wasn't trying to lower it or gain any significant handling benefits, the 1st gens have always been nimble enough for me. pwmin, 94 olds vert and primergray 3 Quote
55trucker Posted November 28, 2023 Report Posted November 28, 2023 Gen 2 lateral arms are my personal choice as well, if you pick up 4 adjustable items 2 of them have to be shortened by just over 1", then rethread the shortened long arm end. An M20x1.5 thread die is needed to cut the new thread on the end of the arm. Be choosy looking for the Gen 2 arms, you want an aftermarket arm that has next to near non flexible bushings pressed into the *eyes*. rich_e777 1 Quote
Bake82 Posted November 28, 2023 Report Posted November 28, 2023 3 hours ago, 55trucker said: Gen 2 lateral arms are my personal choice as well, if you pick up 4 adjustable items 2 of them have to be shortened by just over 1", then rethread the shortened long arm end. An M20x1.5 thread die is needed to cut the new thread on the end of the arm. Be choosy looking for the Gen 2 arms, you want an aftermarket arm that has next to near non flexible bushings pressed into the *eyes*. Interesting approach to simply cut the new thread. I like that approach! I have a set that was cut in the middle and then re-welded, but the re-threading seems like a better approach! Quote
55trucker Posted November 28, 2023 Report Posted November 28, 2023 ^ Yeah, Matt used to take the *cut & weld* approach, I couldn't understand why he did them that way seeing as he is/was a machinist at the Toyota plant in Woodstock here in Ontario & had access to the needed tools. I prefer to cut the ends & rethread them. rich_e777, SuperBuick, Psych0matt and 1 other 3 1 Quote
Bake82 Posted November 29, 2023 Report Posted November 29, 2023 15 hours ago, 55trucker said: ^ Yeah, Matt used to take the *cut & weld* approach, I couldn't understand why he did them that way seeing as he is/was a machinist at the Toyota plant in Woodstock here in Ontario & had access to the needed tools. I prefer to cut the ends & rethread them. Yes Matt did mine way back, but now they need bushings. Now I know the better way I can do way easier myself if I ever need to! Thank you again! Quote
rich_e777 Posted December 9, 2023 Author Report Posted December 9, 2023 I`ll have to find a machine shop around here I like that would do that, and take them an old one to get the precise measurement. I got to looking at putting a RTSB on it and found out there isnt a single nut holding the rear strut mounts to the body. No freakin wonder the back end feels off going down the road and over bumps! I cant believe these never got a similar badge or emblem like the ACS Capri`s did, these are cool... and for the price I think I`m going to get one for the trunk lid or underneath one of the tail lights. https://www.ebay.com/itm/233771782014?var=0&mkevt=1&mkcid=1&mkrid=711-53200-19255-0&campid=5338590836&toolid=10044&customid=1582473de84f1b999b3022494df32e2c 94 olds vert and pwmin 2 Quote
rich_e777 Posted April 5, 2024 Author Report Posted April 5, 2024 Ehh, I dont hate it but it sort of looks funny being the only "chrome" on the car. Might have looked better above the tail light instead. It has little lines going through it like retro things did back then that match the grids in the tail lights and ribs in the bumpers in a very OCD friendly way. pwmin and 94 olds vert 2 Quote
94 olds vert Posted April 5, 2024 Report Posted April 5, 2024 Jealous of your antique plate. I can't wait to get one on my GTP. Quote
rich_e777 Posted April 7, 2024 Author Report Posted April 7, 2024 (edited) Just a year away though. Ive had it about a year and driven it at least 200mi and the oil is still clear with a slight amber hue. She needs a dedicated garage spot to be parked in doors, its in WAY to good of shape for an `89 to just be covered in the driveway. I wish I could keep it like a Countach or Testarossa, thats the idea anyways. Edited April 7, 2024 by rich_e777 Quote
Psych0matt Posted April 7, 2024 Report Posted April 7, 2024 not sure how i missed this before, but nice grab! rich_e777 1 Quote
rich_e777 Posted April 12, 2024 Author Report Posted April 12, 2024 It had to be saved, it was going to the Jawas otherwise. All Jiggity57`s fault for posting it. I got into a bit of a race the other day when I probably shouldnt have. I made a right turn and immediately found a speeding BMW attempting to swerve around me from a sharp corner in the right lane. I laid into the pedal a bit, chirped the tires and heard an awesome turbo wastegate PAHHTISHHHHH and left the kraut cart far into the rearview mirror. Scared the hell out of me and blew the lower hose off the turbo in the process. I love this freakin` car! Decades after WW2 and we can still put the Messerschmitt`s in their place, just not in a P51 Mustangs. 94 olds vert, primergray, Amanita and 1 other 1 3 Quote
