ctaco Posted July 27, 2022 Report Posted July 27, 2022 The turn signal will turn on my blinkers, but only when slightly depressed. When I depress the level until it clicks into place, it the blinkers do not work. If I am careful, I can lightly press the right side down and get it to flash then continue to press it until it clicks and it sometimes stays on, but the left side will never do that. All bulbs are working, hazards work, fuses all seem fine. Is this my turn signal lever itself or something else? Quote
GTP091 Posted July 27, 2022 Report Posted July 27, 2022 (edited) If the bulbs work your wiring is good. If your hazards work the flasher is good. I’d go with the lever and your first hunch. Watch some YouTube videos and hit up rock auto or a JY for the part. Go with an OEM part not a Chinese ripoff or you’ll get really good at changing them out. Edited July 27, 2022 by GTP091 ctaco 1 Quote
