bluecalais79 Posted April 12, 2022 Report Posted April 12, 2022 Good morning, for a 1996 CS 2 door, does any one know if any techniques to use in pulling off the plastic armrest piece that holds the power window, power door lock and power mirror switches? I am looking to replace the switches and I'm hoping to pop off the piece without breaking the 2 tabs. Thx, if anyone has done this one before, much appreciated. Quote
bluecalais79 Posted May 2, 2022 Author Report Posted May 2, 2022 I finally got around to taking a crack at this task over the weekend. Using the plastic piece which contained the 3 switches I bought as a guide I pushed in and up on that plastic piece that holds the 3 switches and it popped right out without braking any of the tabs, fortunately. After pulling the 3 plug ends out I went about removing the switches from the piece and that also went well, I used a pry tool, not a screwdriver. For my replacement switches, the mirror switch I had was NOS, but the door lock and power window switches were nice used. In an effort to preserve the black paint and lettering on the door lock and window switches I clear-coated them which may in the long run be a mistake but we'll see. I primarily wanted to replace the power window switch as the Auto-down was no longer working, and I was right. I tested the new switch before putting everything all back and sure enough my Auto-down now works great. The only bummer is the illumination for the door lock switch is barely visible and the illumination for the window switch is not illuminated at all. Oh well, can't have everything. I can live with that. I just won't drive the car at night. Quote
darklotus42 Posted October 28, 2024 Report Posted October 28, 2024 If you take apart the window switch you can replace the bulb. First pop the buttons off with a small flat head the take off the rubber gasket you will see a clear plastic illuminator clipped in below the switches. Be very careful taking it off as they break easily. The bulb is under there. I can't remember if you can. Remove it from there or if you have to do further surgery. Let me know and I can walk you through complete disassembly. Quote
bluecalais79 Posted November 30, 2024 Author Report Posted November 30, 2024 Thanks but I'll let that one be. The next time I pull that door panel will be to replace the speaker when it dies. THis stuff can break by just looking at it wrong, so I will live with the low illumination. Quote
