Regal Posted January 31, 2022 Report Posted January 31, 2022 (edited) Some months ago I used my '93 Regal coupe to tow a trailer that was probably a bit too much for the car. Soon after I've been hearing a helicopter whirring sound from that back that increases with acceleration. To replace what must be the 30 year old factory hub/bearings I've ordered new hub/bearings as RockAuto seems to be giving away Moog rears on wholesale clearance (also managed to snag some upper and lower Continental radiator hoses for like $5 also on wholesale clearance). I've replaced an ABS hub bearing in the front before but am just curious what's involved with this job in the rear; I imagine much the same? Hopefully better than replacing the damned rear struts! Would be the same as the '89-'96 Cutlass and Grand Prix. Edited January 31, 2022 by Regal Quote
55trucker Posted January 31, 2022 Report Posted January 31, 2022 As hard nosed & callous as this may sound...... pick up a service manual set.......it's your *best friend* everything is explained within https://www.ebay.com/itm/353702360779?_trkparms=ispr%3D1&hash=item525a4db6cb:g:QkEAAOSwDFJhaPiB&amdata=enc%3AAQAGAAACoPYe5NmHp%2B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsSd0ReTLyM7cxPnI6zs468EIEc%2BYcj47p2%2BGXsqB3GSf7II0s04xLatl5gokMJapt3kJK8jghzKEsENxLhvUh%2FP4bxzjUrGgR8%2FakXEszfGLs6YAS6C3teyjYXx6tvFmA1AK09qBIxYfoZq7%2Bpkru0SYlywOMZUpUDWlOUYcT%2ByQ%2BKDXpF5QrPb8ipzqqnYRcfDGy3QFUVd3jVP1QrPslfEovlCQBi2FzS86SWNFw4uMlGOboZLnuvvutyrN%2Fi%2F578yVQ%2BRZp%2BjUjgz5Mo8viWvyYj%2FEW4yFmifGHZPX1xE%2BhhJglc7cQgA1ZMKmmktljkNxatbqPVLCcZxO1AAETXaWjBVj6hYRoOYjwdIVF5qqpHdK4lBfZm4nxdi24jpZJNdkpdifyP7uXgjdPC%2FvIBVEWEYm0uBZlsVrFeQAq9wXGrjmfkBzBdF3UU8ouAQ2n4onS%2FyypPa3omC0p1pxDFtSVqqidfd6szPnqrYCTEskFQ%2BskgjpQVy5%2FH9dqiktV5m%2BUikgo6QVBevOVakcUKBeVP0at0p5Vg3k%2F3O6rv23r90stKwSTMYFKISu%2FQl6TM0kULX1Z8HDM6BRoXGU0dZD4TQo0CPs2aInbDBDfNeilv5ku9skCdeENzOmi3DXayMWTQ2Yf6n3%2FnSH538s2YGcaHhDPcoG6JLYGfKAvDenfElOzDBFGAq1PUWlIhp%2BXi6NPWf0eKOkKTUGG92KuflK7XV8Mo%2BQDZZkplYhp12FtHpmMUBG7QpD0N1CF1BFEHzsnRs89y%2FWOWeRlWGNzZWRsrtTOM1YUSufwocLAQgruE6SQn6PxQKzk8dum5K3fXHr%2FB6FgzZSZXrGY%2BlW7O2Q%3D%3D|clp%3A2334524|tkp%3ABFBMoqjRldZf 94 olds vert 1 Quote
oldmangrimes Posted January 31, 2022 Report Posted January 31, 2022 I've changed all four hubs on my 95 Cutlass. The rear is easier of course because of no axle to mess with. The first hub I replaced, I had a little difficulty separating it once the bolts were removed, it had been in place for decades and was a little rusty. I was too gentle, as I don't like to hit my own car too hard. PB Blaster overnight and tapping didn't loosen it. Eventually frustration set in and I got out the sledgehammer and it came apart quickly. (Also, this is not the only time in my life I've said "eventually frustration set in and I got out the sledgehammer and it came apart quickly") Nas Escobar 1 Quote
rich_e777 Posted January 31, 2022 Report Posted January 31, 2022 Rear hubs are SIMPLE, they come off and go back on exactly like you think they would. 2nd on the service manual, its got all the info for torque specs and exploded diagrams. Nas Escobar 1 Quote
Bubinga Posted February 3, 2022 Report Posted February 3, 2022 On 1/31/2022 at 12:54 PM, Regal said: Some months ago I used my '93 Regal coupe to tow a trailer that was probably a bit too much for the car. Soon after I've been hearing a helicopter whirring sound from that back that increases with acceleration. To replace what must be the 30 year old factory hub/bearings I've ordered new hub/bearings as RockAuto seems to be giving away Moog rears on wholesale clearance (also managed to snag some upper and lower Continental radiator hoses for like $5 also on wholesale clearance). I've replaced an ABS hub bearing in the front before but am just curious what's involved with this job in the rear; I imagine much the same? Hopefully better than replacing the damned rear struts! Would be the same as the '89-'96 Cutlass and Grand Prix. You don't think the front bearings hub assembly for a 2001 Grand Prix SE are on sale are they ? Quote
