Addicted To Boost Posted September 10, 2021 Report Posted September 10, 2021 I have a question for those of you who have installed KYB GR2s in the front of your first gen: After sliding the strut down into the knuckle, you install the strut retainer ring and thread it into the tube of the knuckle- Is the retaining ring supposed to bottom out in the knuckle? I'm pretty sure the OE retaining ring fully bottoms out into the tube when paired with the OE strut. I've verified with both the OE ring and the ring included with the GR2s that they both fully thread into the tube and bottom out with no strut installed. If I install the GR2 strut, the ring will thread into the tube about halfway, then it gets tight. I can physically feel that about half the threads are still exposed and the ring does not bottom out into the tube- I feel like it should, though. For those who have GR2s on their car- is this right? Quote
White93z34 Posted September 10, 2021 Report Posted September 10, 2021 it depends, does it keep the strut firmly in place? I had an instance on my one TGP where the threads were crossed about partway down and let an extra 10-15mm of play in the strut which sounded just fantastic Go4DaMo 1 Quote
Addicted To Boost Posted September 10, 2021 Author Report Posted September 10, 2021 (edited) It seems to hold it, from what I can tell. But, I haven't reassembled it any further than that. I took the strut out and verified that it will thread all the way down and bottom out by hand. It just doesn't bottom out on the tube of the knuckle when the strut is installed. Seems less than ideal. Edited September 10, 2021 by Addicted To Boost Quote
55trucker Posted September 10, 2021 Report Posted September 10, 2021 It's been a long time since I did the front shocks, when you stand the 2 shocks side by side is the KYB item slightly longer than the old OEM? The retaining ring shouldn't *bottom* out when the shock is in place, it has to apply pressure to the shock housing to secure the shock into position. Quote
Addicted To Boost Posted September 11, 2021 Author Report Posted September 11, 2021 (edited) Well, I have the KYBs installed and locked down. Steve, the KYBs are indeed slightly longer than the OE cartridges. They feel solidly secured, but I suppose I'll find out if this is correct once I take it for a drive and see if it makes noise. Edited September 11, 2021 by Addicted To Boost Quote
55trucker Posted September 11, 2021 Report Posted September 11, 2021 It's been 10 years since I did the fronts, I also installed KYB's, except for being (in my opinion) too soft they have been trouble-free, also noise free. Quote
GTP091 Posted September 11, 2021 Report Posted September 11, 2021 I have a set of kyb’s on my GTP and don’t have this issue. You checked there’s no spacer or something in the bottom of the shock tube? Quote
Addicted To Boost Posted September 15, 2021 Author Report Posted September 15, 2021 Yeah, there was nothing in the bottom. They did lock down securely and didn't make any noise when I drove it, so it seems that's just how they are. Quote
GTP091 Posted September 15, 2021 Report Posted September 15, 2021 If you got enough turns in to get it halfway I’d say drive it. Hope you smeared some anti seize on em though or they’ll be a bugger later. Quote
Addicted To Boost Posted September 18, 2021 Author Report Posted September 18, 2021 Yes, it has been fine so far. There is probably some oil on the threads from the factory-filled tubes, but more than that is probably unnecessary here in AZ. Quote
