06goat75 Posted August 25, 2021 Report Posted August 25, 2021 I've been sorting out the AC in my '95 3.4. It developed a small leak, which I think I tracked down. The valve in the low pressure side is leaking, so gonna replace it. While sorting the AC out, the compressor has developed a squeal, no matter if the clutch is engaged, or not. AC has never been something I've enjoyed working on, so trying to figure the best way forward. Is a compressor replacement necessary? Or can I just do the clutch/pulley? Can you even replace the clutch in the car? Or is removal necessary, which at that point, might as well replace the entire compressor. Thanks for the advice! Quote
Schurkey Posted August 26, 2021 Report Posted August 26, 2021 I bet the '95 service manual would have the info on whether the clutch could be replaced in-car. First Guess: No room for tool clearance. Quote
