mechanic58 Posted June 27, 2021 Report Posted June 27, 2021 (edited) Just picked this up today, ‘93. Unmolested one owner Carolina car. Been parked a long time. Timing belt failure. Edited June 27, 2021 by mechanic58 Changed the picture links 94 olds vert, jiggity76, 89-W-Body-Regal and 7 others 9 1 Quote
Jim_rockford_007 Posted June 27, 2021 Report Posted June 27, 2021 Needs more L67. jiggity76, mechanic58, pwmin and 2 others 2 1 1 1 Quote
mechanic58 Posted June 27, 2021 Author Report Posted June 27, 2021 1 minute ago, Jim_rockford_007 said: Needs more L67. You shut your whore mouth when men are talking! jiggity76, pwmin and rich_e777 1 2 Quote
mechanic58 Posted June 28, 2021 Author Report Posted June 28, 2021 Got this thing torn down today and cleaned up. Ordered some parts. I may have it running later this week. LQ1 parts are all closeout priced on rock auto, the timing belt was only $2.14! jiggity76, pwmin, rich_e777 and 1 other 3 1 Quote
mechanic58 Posted June 29, 2021 Author Report Posted June 29, 2021 Aaaaaannnnd we have a willing donor… rich_e777, 94 olds vert and Jim_rockford_007 3 Quote
Jim_rockford_007 Posted June 29, 2021 Report Posted June 29, 2021 I can still smell the burnt transmission fluid from here. Quote
Jim_rockford_007 Posted June 29, 2021 Report Posted June 29, 2021 20 hours ago, mechanic58 said: Aaaaaannnnd we have a willing donor… Why not show the entire Turd ..lol Quote
Amanita Posted June 30, 2021 Report Posted June 30, 2021 Taking the LQ1 out? Shame the '93 engine isn't a drop in fit in my '96 Grand Prix or I'd ask if it's for sale. jiggity76 1 Quote
mechanic58 Posted June 30, 2021 Author Report Posted June 30, 2021 5 hours ago, Amanita said: Taking the LQ1 out? Shame the '93 engine isn't a drop in fit in my '96 Grand Prix or I'd ask if it's for sale. Not sure yet, I might. Depends on how well I like how it runs and performs. I’ve never had any experience with one. Had plenty with the sc 3800’s though, so we’ll see. IF it ends up coming out it will definitely be for sale - engine and trans, complete. jiggity76 and pwmin 2 Quote
pwmin Posted July 1, 2021 Report Posted July 1, 2021 L67 swaps are fun and were cool back in the day, but for me, with a car that nice, if you can get the 3.4 running, there's no way I would do the swap. It's your car, so you do what you want with it, but although it lacks in power, the 3.4 sounds better and is more fun to rev out. jiggity76 and TX_LaCrosse 2 Quote
mechanic58 Posted July 1, 2021 Author Report Posted July 1, 2021 10 hours ago, pwmin said: L67 swaps are fun and were cool back in the day, but for me, with a car that nice, if you can get the 3.4 running, there's no way I would do the swap. It's your car, so you do what you want with it, but although it lacks in power, the 3.4 sounds better and is more fun to rev out. More than likely that’s what will end up happening, but this car has been parked for a very long time and there is evidence that it is had a transmission change at some point. Now I’m worried about it having the correct final drive ratio. If it got a transmission with a taller final drive ratio it’ll kill this thing. I guess I’ll find out soon. I took the gas tank out of it last night and cleaned it up and got all the rotten fuel out of it. The new fuel pump will be here today along with the rest of the parts I ordered for the engine. However even if I do get it running this weekend I still won’t be able to drive it because the brakes are fossilized. That’ll be a project for another weekend. pwmin and jiggity76 2 Quote
mechanic58 Posted July 2, 2021 Author Report Posted July 2, 2021 Welp, got the Z34 running. Still has some issues, for some reason the tach does not work and the engine does not want to rev up. When you attempt to open the throttle all the way it acts like the rev limiter is stopping it from revving up. It’s also either running lean or leaking raw fuel into one or several cyls because the converter is getting hot. I suspect it’s going to need fuel injectors. The engine noise that you hear in the video cleared up after it ran for a little while. Especially after I changed the oil. jiggity76 1 Quote
55trucker Posted July 2, 2021 Report Posted July 2, 2021 The cat may be your issue, engine idles reasonably well but is not capable of higher rpms due to the exhaust being clogged. Quote
jiggity76 Posted July 2, 2021 Report Posted July 2, 2021 2 hours ago, mechanic58 said: Welp, got the Z34 running. Still has some issues, for some reason the tach does not work and the engine does not want to rev up. When you attempt to open the throttle all the way it acts like the rev limiter is stopping it from revving up. It’s also either running lean or leaking raw fuel into one or several cyls because the converter is getting hot. I suspect it’s going to need fuel injectors. The engine noise that you hear in the video cleared up after it ran for a little while. Especially after I changed the oil. Very cool that you got her running! Congrats man! Please tell me that you kept those original plug wires. Hopefully the motor will give you years of enjoyment. I really want it to stay with the car if at all possible. The best thing for that car is for it to get moving! pwmin 1 Quote
mechanic58 Posted July 2, 2021 Author Report Posted July 2, 2021 17 minutes ago, jiggity76 said: Very cool that you got her running! Congrats man! Please tell me that you kept those original plug wires. Hopefully the motor will give you years of enjoyment. I really want it to stay with the car if at all possible. The best thing for that car is for it to get moving! No, they were trash. I suspect the icm is bad. If that ends up being the case I probably wont fix it and it’ll come out. Not too impressed with this engine anyway. Quote
mechanic58 Posted July 2, 2021 Author Report Posted July 2, 2021 (edited) 2 hours ago, 55trucker said: The cat may be your issue, engine idles reasonably well but is not capable of higher rpms due to the exhaust being clogged. Nope. Clogged cats are a myth. That **** only happens to trash people who drive around in garbage they never change oil in, etc. Edit: I’ve been working on cars for 35 years, never seen an actual clogged cat. Edited July 2, 2021 by mechanic58 Quote
pwmin Posted July 2, 2021 Report Posted July 2, 2021 Hmm, my mom's 01 GT SPED has had that happen and it's not garbage. Quote
55trucker Posted July 2, 2021 Report Posted July 2, 2021 Good for you, I've got 13 years on you, if the cat suffered a meltdown because something up stream in the fuel management system failed then the converter substrate collapsed into particles and have collected in the system then the exhaust will be clogged. Quote
mechanic58 Posted July 2, 2021 Author Report Posted July 2, 2021 Clogged/melted cats are extremely rare, that is a fact. Its not the cat in this case. Quote
55trucker Posted July 2, 2021 Report Posted July 2, 2021 Cats don't fail on their own, as I said something upstream where the fuel management system has to fail to cause the substrate to collapse, it will clump into chunks of solid material causing a restriction in the exhaust. Quote
mechanic58 Posted July 2, 2021 Author Report Posted July 2, 2021 I’m not going to argue with you anymore. There is no problem with the cat or the exhaust on this car. The hot cat is a symptom of another problem. Quote
Amanita Posted July 2, 2021 Report Posted July 2, 2021 How many miles are on the engine? I think the bottom end is the same between '93 and '96. If the miles are low enough I might be interested in the LQ1 in the future should you be looking to get rid of it. mechanic58 1 Quote
