89-W-Body-Regal Posted June 18, 2021 Report Posted June 18, 2021 (edited) I have an 89 Buick Regal Custom and I have to do a wheel hub bearing on the drivers side. I was wondering what size impact socket I could use that would remove the spindle nut. I don’t have any size that will remove the nut. So I would appreciate it if you can give me the exact size without guessing. Edited June 18, 2021 by 89-W-Body-Regal Quote
GTP091 Posted June 23, 2021 Report Posted June 23, 2021 As usual Manic is correct. You will need a good breaker bar. Use a wire brush to clean the threads up and Hit with penetrating oil first. Your hub looks corrosion free so your lucky there. 89-W-Body-Regal 1 Quote
