Minty442 Posted May 28, 2021 Report Posted May 28, 2021 Need to replace it , can't find one online anyone got a hook up or should I just clean up mine. If u lock door try to open while locked it won't open again till u pull off panel and manually reach under assembly and open Quote
pwmin Posted May 29, 2021 Report Posted May 29, 2021 I seen to have some recollection of a fairly recent thread on this. Someone that knows more than me will surely chime in. Quote
55trucker Posted May 29, 2021 Report Posted May 29, 2021 15 hours ago, Minty442 said: If u lock door try to open while locked it won't open again till u pull off panel and manually reach under assembly and open I wouldn't expect the door to open while it is locked, one has to unlock the door 1st. Quote
jiggity76 Posted June 4, 2021 Report Posted June 4, 2021 (edited) On 5/28/2021 at 5:11 PM, Minty442 said: Need to replace it , can't find one online anyone got a hook up or should I just clean up mine. If u lock door try to open while locked it won't open again till u pull off panel and manually reach under assembly and open You need a driver's door latch for a Cutlass convertible? Is that what you're after? Edited June 4, 2021 by jiggity76 Quote
