Bens70w31 Posted March 24, 2021 Report Posted March 24, 2021 Quick question to the group.... can somebody please tell me the Delco part# or quality aftermarket turn signal flasher relay. Id be very much greatful. 97 Supreme 4 door. Quote
mfewtrail Posted March 25, 2021 Report Posted March 25, 2021 (edited) ACDelco 19209674 There's an older stock one on ebay right now that's USA made: https://www.ebay.com/itm/174691238123?chn=ps&mkevt=1&mkcid=28 Pretty sure if you order anywhere with newer stock, you'll receive a China made flasher... Edited March 25, 2021 by mfewtrail jiggity76 1 Quote
Bens70w31 Posted March 30, 2021 Author Report Posted March 30, 2021 On 3/25/2021 at 4:23 PM, mfewtrail said: ACDelco 19209674 There's an older stock one on ebay right now that's USA made: https://www.ebay.com/itm/174691238123?chn=ps&mkevt=1&mkcid=28 Pretty sure if you order anywhere with newer stock, you'll receive a China made flasher... Thank you ! Quote
mfewtrail Posted March 30, 2021 Report Posted March 30, 2021 22 hours ago, Bens70w31 said: Thank you ! You're welcome. If you went to the ebay link, you should be note that the AC Delco flasher is just a reboxed Wagner product. Searching that Wagner number will lead you to more USA made new-old-stock flashers. Quote
Bens70w31 Posted April 1, 2021 Author Report Posted April 1, 2021 On 3/30/2021 at 7:03 PM, mfewtrail said: You're welcome. If you went to the ebay link, you should be note that the AC Delco flasher is just a reboxed Wagner product. Searching that Wagner number will lead you to more USA made new-old-stock flashers. Thanks again!!! Appreciate your attention . I ended up with a new Wagner I sourced locally. Quote
Bens70w31 Posted April 2, 2021 Author Report Posted April 2, 2021 (edited) I posted on the general discussion of installing LEDs in the front turn signals from incandescent bulb # 3157 . I went with LEDS and now noticed both directional signal arrows inside the cluster are dimmly lit (continuous) They flash completely normally when turn signals are activated. Is the cause of the feed to the directional arrows the issue of (polarity) of the front bulbs or does the car not like LEDS in the front? Im fairly certain before I installed the outrageously expensive LEDS that the turn arrows stay dark and unseen with incandesents. Anyone have this small issue happen to them and if so does anyone know the fix ? Thanks in Advance! Edited April 2, 2021 by Bens70w31 Quote
carkhz316 Posted April 2, 2021 Report Posted April 2, 2021 The LEDs have such a high internal resistance that it behaves like a "bad ground" sometimes, and can cause the issue you describe with the the turn signal indicators. If you were to replace the indicators with LED, or add a resistor to the turn signal bulbs out on the car (like you would to cure "hyper flash"), it should fix the issue. You can test it by swapping a standard bulb on one side, or simply using jumper wires to add it to the circuit to test it. Quote
Bens70w31 Posted April 6, 2021 Author Report Posted April 6, 2021 On 4/2/2021 at 9:14 AM, carkhz316 said: The LEDs have such a high internal resistance that it behaves like a "bad ground" sometimes, and can cause the issue you describe with the the turn signal indicators. If you were to replace the indicators with LED, or add a resistor to the turn signal bulbs out on the car (like you would to cure "hyper flash"), it should fix the issue. You can test it by swapping a standard bulb on one side, or simply using jumper wires to add it to the circuit to test it. I went back with incandescents and the problem went away. That thought ran through my mind by adding a ground wire. Instead of the hassle I just stuck with 3157 amber incandescent. Lot cheaper than 21 $ leds. Quote
