jiggity76 Posted March 13, 2021 Report Posted March 13, 2021 Does anyone know if the LQ1's used the same coil packs from 91-97? Thanks guys. Quote
55trucker Posted March 13, 2021 Report Posted March 13, 2021 (edited) The 3 individual coils are a common item, the same item has been in use going back to approx '87 on all the engines (excluding the 8's) that were distributorless to the mid 2000's. Edited March 13, 2021 by 55trucker jiggity76 and pwmin 1 1 Quote
jiggity76 Posted March 13, 2021 Author Report Posted March 13, 2021 (edited) Thanks 55! Yeah, it looks like they do. It took me awhile but I found the part #'s. The 97 LQ1's used or can use the coil packs with part #10482928. My 91 car has the same part # coil pack. I just ordered 2 complete NOS sets. Edited March 13, 2021 by jiggity76 Quote
55trucker Posted March 15, 2021 Report Posted March 15, 2021 When you get around to reinstalling the coils do not mismatch the pair of plug wires to each individual coil. Altho these are a *batch fired* arrangement & both sides of the coil fire, the cylinder that IS firing receives the primary discharge & the other side of the coil delivers a reversed polarity/reduced voltage to the paired cylinder that is on the valve overlap. Quote
Schurkey Posted March 16, 2021 Report Posted March 16, 2021 11 hours ago, 55trucker said: When you get around to reinstalling the coils do not mismatch the pair of plug wires to each individual coil. Altho these are a *batch fired* arrangement & both sides of the coil fire, the cylinder that IS firing receives the primary discharge & the other side of the coil delivers a reversed polarity/reduced voltage to the paired cylinder that is on the valve overlap. No, not really. There is ONE spark pulse per coil. It travels down one plug wire, crosses the spark plug gap. Travels through the conductive metal engine to the other spark plug that the coil is paired with. Jumps that plug in the reverse direction. Travels up the plug wire where it completes it's circuit in the secondary windings of the coil. The plug that fires in the normal direction, ALWAYS fires in the normal direction. The plug that fires in reverse polarity ALWAYS fires in reverse polarity. The polarity does not switch back and forth depending on whether the cylinder is firing on compression stroke or exhaust stroke. Thus the extra-high voltage on these coils--they have to be powerful enough to fire a spark plug with reverse-polarity and still get a reliable spark-and-burn in that cylinder. This is also why you don't install "regular" Platinum plugs in a waste-spark ignition system. Half the plugs will have the platinum on the wrong side of the arc. You'd need "double-Platinum" plugs for this application. rich_e777 1 Quote
jiggity76 Posted March 16, 2021 Author Report Posted March 16, 2021 Yeah, I have no idea what you guys are talking about. I just installed the wires back where they originally were and using OEM plugs. Quote
55trucker Posted March 17, 2021 Report Posted March 17, 2021 On 3/15/2021 at 11:59 PM, Schurkey said: No, not really. There is ONE spark pulse per coil. It travels down one plug wire, crosses the spark plug gap. Travels through the conductive metal engine to the other spark plug that the coil is paired with. Jumps that plug in the reverse direction. Travels up the plug wire where it completes it's circuit in the secondary windings of the coil. The plug that fires in the normal direction, ALWAYS fires in the normal direction. The plug that fires in reverse polarity ALWAYS fires in reverse polarity. The polarity does not switch back and forth depending on whether the cylinder is firing on compression stroke or exhaust stroke. Pardon my *advanced age & the continual brain short circuits*......must be the prescription drugs I am on for the spinal stenosis..... what I should've explained is that the cylinder which is on the compression stroke receives the bulk of the discharge while the cylinder on the valve overlap receives a reduced coil discharge seeing as it does not require a * full squirt*, the magnetic cam synchronizer circuit looks after that. rich_e777 1 Quote
