TGP throttle body (17089084) replace/rebuild
Does anyone know where I can get a throttle body rebuild/replacement for my 1989 TGP?
The throttle body is the same on all other 3.1 MPFI engines, so a junkyard unit in better shape than yours is probably your best bet. What exactly is wrong with yours?
Depending on what year 3.1 MPFI you pull a throttle body off of, you may need to swap the vacuum distribution block for the one off your original tb. The later cars had electronic egr's, so they only have three vacuum ports on top instead of four.
