sho89mtx Posted January 13, 2021 Report Posted January 13, 2021 SO had a guy install the f-body brake upgrade and all new rotors and pads on the rear from ZZP and when I got it back, the brake pedal was way too spongy and it's now back with him trying to get fixed and he can't figure it out. The f-body upgrade is suppose to be a huge difference in braking power, and after he installed everything, the brakes were actually much worse, i had to pump them just to stop. That's the last time I use this guy! I had a guy before, but this guy said he could do it much cheaper, apparently he can't! Quote
Psych0matt Posted January 13, 2021 Report Posted January 13, 2021 My guess is it isn’t bled all the way. GTP091 and Dat50go 2 Quote
Walterintx Posted March 26, 2021 Report Posted March 26, 2021 Did he put a different master cylinder on the car? I read before on another forum where you had to put a bigger master cylinder on with certain larger calipers to make up for the increase in fluid needed to push the larger diameter pistons or else end up with a very spongy pedal. Quote
