ManicMechanic Posted November 3, 2020 Report Posted November 3, 2020 5 minutes ago, jonosso said: Wow! A lot of back and forth!!! It was quite an involved process for sure! jonosso 1 Quote
ManicMechanic Posted November 3, 2020 Report Posted November 3, 2020 I'm done with Angelo, I think his cornflakes done gone soft.. jonosso 1 Quote
kcac Posted November 3, 2020 Report Posted November 3, 2020 (edited) 2 hours ago, ManicMechanic said: Very sloppy welds, factory welds would have been much neater. The front fenders looked as though they were cut with a reciprocating saw and two large holes drilled for bolts. Under a cover on each front door is where they hacked off the door b-pillar and re welded it back on and it looked like a baboon was using the welder, seriously. That's disappointing to hear. I almost wish I had not asked. I mostly like the look of the car when the top is down, but every now and then I am somewhat bothered by how the folded up top sits on the back of the car instead of presenting more flattened, streamlined appearance as vehicles designed as convertibles do. Makes me wonder how much better car could have been if a convertible variant had been designed from the ground up for assembly on the line vs the coupe conversion. Edited November 3, 2020 by kcac ManicMechanic and jonosso 2 Quote
jonosso Posted November 3, 2020 Author Report Posted November 3, 2020 I joined the Doraville Plant Facebook group and asked about all of this. Check out this response from one of the plant workers. This is awesome history. sean1991olds, rich_e777 and ManicMechanic 3 Quote
kcac Posted November 3, 2020 Report Posted November 3, 2020 (edited) 1 hour ago, jonosso said: I joined the Doraville Plant Facebook group and asked about all of this. Check out this response from one of the plant workers. This is awesome history. Thanks for posting the plant worker's reply. It is very interesting. Maybe you will hear from someone who worked for Cares and Concepts (C and C) and get some information on the conversion process from their point of view. When I bought my convertible in 2007, I thought I was buying a factory-built car that had been designed as a convertible. They still look pretty good for a conversion convertible, but from what ManicMechanic reported, there is a lot of sloppy work hidden under the trim pieces. And if Oldsmobile was losing $10,000 on every convertible, you have to wonder how much pressure C and C was under to convert the cars as fast as possible for the least amount of effort. That might account for what ManicMechanic saw. Thanks again for sharing the worker's recollections. Sounds like the conversion was anything but streamlined. Edited November 3, 2020 by kcac jonosso 1 Quote
jonosso Posted November 3, 2020 Author Report Posted November 3, 2020 I have also pressed my luck to see if anyone might have some insight on the top seals. rich_e777 1 Quote
kcac Posted November 3, 2020 Report Posted November 3, 2020 Thanks for your persistence in looking into this. jonosso 1 Quote
rich_e777 Posted November 4, 2020 Report Posted November 4, 2020 The Chinses company that bought out C&C would be the first step in finding out who made the seals, I thought someone there might be cool enough to look into it if I can get them on the phone. I dont have time this morning but might this weekend. jonosso 1 Quote
Awrench Posted March 30, 2021 Report Posted March 30, 2021 (edited) Soffseal made all three w/strip designs. Scott Hayes done a great job of explaining the process. Early design, 91 thru 92 had a 'butt joint' type w/strip mating connection. Running change in late 92 began the angle type connection and 93 into 94 and 95 was the final and best design of a ball and socket type. 'A' pillar w/strip final was the one with the drain hole in the runner when standing over corner. The tops were made wider by approx. 1.5 inches in late 94 production to help cover the side window w/strips and aid in water leaks. The Body in Whites were sent over three at a time on a side curtain type covered trailer that would pull alongside the dock at C&C and then put on the Flat Table to be reinforced with eventually I believe just over 100 braces of sorts. Then the top came off. Edited March 30, 2021 by Awrench To make clear jonosso, rich_e777 and pwmin 3 Quote
jonosso Posted March 31, 2021 Author Report Posted March 31, 2021 Wow!!!! This is great information. Did you work at the Doraville Plant? Quote
rich_e777 Posted March 31, 2021 Report Posted March 31, 2021 I`ll send them a message and see what sort of reply I can get back. Quote
Denis Spencer Posted August 12, 2023 Report Posted August 12, 2023 Hello all I hope you could help me. I'm looking to purchase a 1995 Cutlass Supreme Convertible but like you have a spoken about the rear quarter trim seals are gone totally cracked and brittle . Have had any look finding any after market seals. To replace the seals(12503936,12503937). If you could give me an update I would appreciate it. Thanks Denis Quote
rich_e777 Posted August 12, 2023 Report Posted August 12, 2023 (edited) We`re still up the creek without a paddle, I found a LinkIn account for a Soffseal HQ in Ohio. I`ve made a note to call them Monday during business hours and see what I can find out. https://www.linkedin.com/company/soffseal-inc. Fairchild Industries looks promising too. Edited August 12, 2023 by rich_e777 Quote
Denis Spencer Posted August 13, 2023 Report Posted August 13, 2023 Thanks for the heads up I appreciate it. Denis Quote
jonosso Posted August 13, 2023 Author Report Posted August 13, 2023 12 hours ago, Denis Spencer said: Thanks for the heads up I appreciate it. Denis Hi Denis. I have not yet followed through with contacting the different manufacturers. I need to do that. Quote
jonosso Posted August 13, 2023 Author Report Posted August 13, 2023 (edited) 18 hours ago, rich_e777 said: We`re still up the creek without a paddle, I found a LinkIn account for a Soffseal HQ in Ohio. I`ve made a note to call them Monday during business hours and see what I can find out. https://www.linkedin.com/company/soffseal-inc. Fairchild Industries looks promising too. Let me know what you find out. I have NOS, never-installed copies of most of the seals that can be used as templates. I have resisted using them because I am hoping we can have them reproduced. Edited August 13, 2023 by jonosso rich_e777 1 Quote
rich_e777 Posted August 13, 2023 Report Posted August 13, 2023 1 hour ago, jonosso said: Hi Denis. I have not yet followed through with contacting the different manufacturers. I need to do that. If we can find some sort of 2d design then Fairchild might be able to help us out. I may even have a decent enough set on my car to remove and send in for the 1995 sizes. Another thought is to create a 3d image ourselves and send that data in and see what they come up with. Crazy K had the idea nearly 20 years ago to redesign the entire seal set from scratch which might not be a bad idea either. 94 olds vert 1 Quote
rich_e777 Posted August 13, 2023 Report Posted August 13, 2023 (edited) 1 hour ago, jonosso said: Let me know what you find out. I have NOS, never-installed copies of most of the seals that can be used as templates. I have resisted using them because I am hoping we can have them reproduced. What year top pieces do you have and which ones might you still need? Just a No.2 intermediate seal from the diagram pic on the 1st page? I will post all the info I can find out. Edited August 13, 2023 by rich_e777 Quote
jonosso Posted August 13, 2023 Author Report Posted August 13, 2023 2 hours ago, rich_e777 said: What year top pieces do you have and which ones might you still need? Just a No.2 intermediate seal from the diagram pic on the 1st page? I will post all the info I can find out. I will have to go to my garage and inventory things. I know I have NOS #1 which I figure is most critical. I think I only have one side for NOS #2, but I imagine that is not a problem because a manufacturer could do a mirror image of the one side. I believe I have NOS of both sides for 3 and 4. rich_e777 1 Quote
rich_e777 Posted August 16, 2023 Report Posted August 16, 2023 The 1-800 on SoffSeals Linkin takes you to the RPUI call center, while friendly the reps there could not find anything out that would help us. Ive also reached out to Fairchild via email and awaiting a reply. Well I had someone on the chatbox at Steele tell me to send them pics of the parts and inquired about the material to use. But the damn site refreshed and I lost his email. If you can lay all your parts out and send them some images they might be interested. Godsson314 and stantmann 2 Quote
JGP Posted August 26, 2024 Report Posted August 26, 2024 Anyone have any progress on this topic? Quote
