jmjp5055 Posted June 8, 2020 Report Posted June 8, 2020 (edited) Good morning People something weird going on with my vert ,after sitting for 24 hours I go to start it, it clicks , it clicks then starts, have new battery, new starter both replaced when this began.when I bring it in ,hasn’t happened for the mechanic yet. Alternator tested , it’s working 13 volt output but dash guage says different 11 to 12 volt , battery no sign of it being dead or low , car starts, heavy draw when power windows or air conditioning used. problem #2 air conditioner compressor would not kick on even when directly jumped by mechanic so I’m out for a Sunday drive I put air conditioning on and wala the compressor kicks on an hour or so then quits, Freon checked BTW, full. So I go to drop car off for compressor replacement , starting problem, no click, turned key at least 3 times, finally turned key held and it took a moment but started. and the air conditioning works again, my mechanic baffled, me baffled. Hope I explained this clearly any suggestions, anyone experienced this? Thanks for any leads Edited June 8, 2020 by jmjp5055 Needed to add the starting symptom Quote
Pontiac6KSTEAWD Posted June 8, 2020 Report Posted June 8, 2020 Sounds like a fusible link to me. I cant remember where they are on these cars. Its either that, or the alternator is going south slowly. Quote
oldmangrimes Posted June 8, 2020 Report Posted June 8, 2020 Maybe a grounding problem? I had a similar no-start problem not with a w-body, with my Dodge Durango. ( I don't think it had anything to do with the A/C but I may not have checked the A/C). Anyway, I was able to get it started by jump-starting itself, meaning that I ran a jumper cable from my battery negative post to the engine block and the car started just fine. I found that I had a corroded terminal on the engine ground cable at the engine, I cleaned it and it's been fine for a couple years. The voltages measured at the battery, alternator showed ok, but if there is very much resistance somewhere in the circuit, the voltage that the device (A/C compressor, car computers, dash gauges, or something else) sees under a surge load (car start, A/C compressor start, etc.) will be low and will cause it to malfunction. Maybe try running a jumper cable to check if the engine block is grounded, or if some other ground is bad. Maybe clean some connections to the suspect component (A/C Compressor). Quote
55trucker Posted June 8, 2020 Report Posted June 8, 2020 Not surprised that the *mech* couldn't figure this one out..... possible ign switch failure.......Not the tumbler assembly, but the switch itself, what you're describing is a classic example of worn contacts failing to make when the key is turned. Quote
