57lxi Posted April 30, 2020 Report Posted April 30, 2020 I know there not made anymore. What are my options. Thinking of getting different configurations from Steele rubber and see what I can come up with that may work. rich_e777 1 Quote
K&R Posted April 30, 2020 Report Posted April 30, 2020 I used the 1993-2002 Camaro outer door belt weather stripping on my 90' Cutlass Convertible. Just cut it down to size and rivet it in. Its shorter than the factory but it still looks good. rich_e777 1 Quote
rich_e777 Posted May 1, 2020 Report Posted May 1, 2020 2nd on the F-body sweeps! You will need a good saw to cut a section off and a rivet gun to install them but it is a good confirmed replacement. I did this years ago and still good. Might add a bit of black RTV to the end you cut. You may have to use google but there was a very good write up on this fix. Quote
