95WhitePrix Posted February 11, 2020 Report Posted February 11, 2020 How hard would it be to replace the exhaust manifold gaskets on a 1995 Pontiac Grand Prix SE 3.1l? Quote
digitaloutsider Posted February 11, 2020 Report Posted February 11, 2020 Not really hard, but I guess that would depend on how rusty things are on the car. Unbolt the crossover, remove the bolts/nuts that hold on each manifold, remove old gasket, install new gasket, bolt it all back together. 95WhitePrix 1 Quote
95WhitePrix Posted February 11, 2020 Author Report Posted February 11, 2020 So I would have to tear down the engine to get access to them then? Quote
digitaloutsider Posted February 11, 2020 Report Posted February 11, 2020 Nope, just remove the bolts/nuts that hold the exhaust crossover on, and get it out of the way. That'll give you more room to maneuver the exhaust manifolds themselves around once they're unbolted. Shouldn't need to take much apart, maybe remove the airbox to get more space (it's been a long time since I've wrenched on a 60 degree motor). 95WhitePrix 1 Quote
95WhitePrix Posted February 11, 2020 Author Report Posted February 11, 2020 Thanks so much for your help! Quote
digitaloutsider Posted February 11, 2020 Report Posted February 11, 2020 No problem. But don't the 60 degree motors have reusable metal exhaust manifold gaskets anyway? What's leading you to replace them? Quote
95WhitePrix Posted February 11, 2020 Author Report Posted February 11, 2020 It has an exhaust leak, I figured that it's probably the gaskets but maybe it isn't Quote
digitaloutsider Posted February 11, 2020 Report Posted February 11, 2020 In my experience, exhaust manifold gaskets rarely fail unless they've been installed incorrectly and pinched or something. If you're up north, the exhaust tends to rust either right before the mufflers or the mufflers themselves. Also seen them rust on the weld joints around the cat. Check there first. Quote
95WhitePrix Posted February 11, 2020 Author Report Posted February 11, 2020 It sounds like it is coming from the back of the engine. It doesn't have alot of rust on it, but I guess something could be rusted out. Quote
digitaloutsider Posted February 11, 2020 Report Posted February 11, 2020 I believe they also have an exhaust donut between the rear manifold and downpipe. Maybe check there, too. You should be able to see black soot around the joints if they're leaking. rich_e777 1 Quote
95WhitePrix Posted May 3, 2020 Author Report Posted May 3, 2020 I think it's leaking from the right rear engine and from the exhaust crossover where it hooks into the rear exhaust manifold, but I don't know how to get the exhaust shield off the crossover. Quote
55trucker Posted May 3, 2020 Report Posted May 3, 2020 i take it that those pesky tiny screws that hold the shield to the crossover are seized into place. Quote
95WhitePrix Posted May 3, 2020 Author Report Posted May 3, 2020 1 minute ago, 55trucker said: i take it that those pesky tiny screws that hold the shield to the crossover are seized into place. Actually they came out, but the shield is blocked from coming out by the master cylinder. Quote
55trucker Posted May 3, 2020 Report Posted May 3, 2020 If memory serves one has to remove the intake snorkel, the throttle body, the coolant thermostat housing & hose to rad, can't remember if the fuel lines are routing directly over top of the crossover. The master shouldn't be an issue. 95WhitePrix 1 Quote
rich_e777 Posted May 4, 2020 Report Posted May 4, 2020 You may have to go up the back of the engine and disconnect the downpipe at the flange, also remove the fan assemblies to give you some more room on the front. I had someone hack my cat converter off years ago and they actually broke the rear manifold in the process, IIRC I rocked the engine forward to get better access to the rear manifold once the front one was off and downpipe disconnected, the coil pack can be removed for better access. I cannot recall and exhaust shield giving my issues though, they are just bolted on and might be rusted together. Quote
95WhitePrix Posted May 5, 2020 Author Report Posted May 5, 2020 I looked at it again and it was actually the brake booster that it was hitting on. Quote
55trucker Posted May 5, 2020 Report Posted May 5, 2020 That doesn't surprise me, that booster is the larger 12" dia item, still shouldn't be an issue to get the crossover out. Release all the crossover bolts, swing back the front portion away from the front manifold, move the entire assembly forward in the direction of the rad & swing up the front half & out it comes. Quote
95WhitePrix Posted May 7, 2020 Author Report Posted May 7, 2020 Does the crossover pipe have gaskets on it? When I searched for them online I couldn't find anything about there being a gasket on it. Quote
55trucker Posted May 7, 2020 Report Posted May 7, 2020 No, both ends are a ball & socket design. Quote
95WhitePrix Posted May 7, 2020 Author Report Posted May 7, 2020 2 hours ago, 55trucker said: No, both ends are a ball & socket design. I wonder why it's leaking then? Quote
95WhitePrix Posted May 10, 2020 Author Report Posted May 10, 2020 I found out that it's the joint that the down pipe connects to on the manifold that's leaking, I'm not sure how easy it would be to replace that gasket. Quote
55trucker Posted May 10, 2020 Report Posted May 10, 2020 That gasket will be a *donut*, depending on when the last time the flange bolt/spring/nuts were undone will more than likely dictate how awkward the job will be. 95WhitePrix 1 Quote
95WhitePrix Posted May 11, 2020 Author Report Posted May 11, 2020 1 hour ago, 55trucker said: That gasket will be a *donut*, depending on when the last time the flange bolt/spring/nuts were undone will more than likely dictate how awkward the job will be. I figure it was never removed. I wonder how easy it is to get to it because it looks crammed back where you can't get to it. Quote
55trucker Posted May 11, 2020 Report Posted May 11, 2020 Usual course of action is from under the car, acetylene for heat, impact gun with a very long extension and a deep socket/swivel on the end. 95WhitePrix 1 Quote
digitaloutsider Posted May 11, 2020 Report Posted May 11, 2020 It'll depend on rust, really. It's been a long time since I worked on a 60 degree, but I think the manifold points down at really awkward angle almost necessitating getting at it from th bottom. Regardless, take a look at the back of the motor and see if you have any clearance from the top. When you're ready to take it apart, I'd let the engine run for a while and get warm, then shut it down, spray some Deep Creep on the threads, then attack it when it's cooled down. White93z34 and 95WhitePrix 2 Quote
