95WhitePrix Posted January 13, 2020 Report Posted January 13, 2020 Hi, I have a 1995 Pontiac Grand Prix SE coupe and I am wanting to know if I can get a remote keyless entry module/transmitter from another Grand Prix that has it installed in add keyless entry to my Grand Prix? And if so, how can I do it? Quote
jimmyfloyd Posted January 13, 2020 Report Posted January 13, 2020 I think there is a way if your car is pre-wired for it. Do a search of the forum 95WhitePrix 1 Quote
digitaloutsider Posted January 13, 2020 Report Posted January 13, 2020 Look in the trunk next to where the antenna is. If it's prewired, there will be a purple wire hanging down. At least I'm pretty sure the late first gens retained the same RKE system. If not, yeah, you could get the parts from a junkyard car and wire it in. 95WhitePrix 1 Quote
White93z34 Posted January 16, 2020 Report Posted January 16, 2020 I've done this on a 95 GP actually. Its pretty easy to wire in but you have to rip into the donor car's wire harness pretty good to pluck out the required wires and chase them all the way back to their termination points and then do the same to your car to wire it in. TBH if you don't have the option, (do check as DigitalOutsider said) its WAY easier to just do an aftermarket solution. 95WhitePrix 1 Quote
95WhitePrix Posted January 16, 2020 Author Report Posted January 16, 2020 If I knew exactly what wires to hook into I would like to add a aftermarket one, but I don't want to mess up all of my wiring if I do it wrong, I was hoping it would somehow be easier to use the module off another Grand Prix but since that's worse, that is out of the question now. Quote
jman093 Posted January 21, 2020 Report Posted January 21, 2020 On 1/16/2020 at 2:29 PM, 95WhitePrix said: If I knew exactly what wires to hook into I would like to add a aftermarket one, but I don't want to mess up all of my wiring if I do it wrong, I was hoping it would somehow be easier to use the module off another Grand Prix but since that's worse, that is out of the question now. Did you check for the purple-wired connector like they suggested? Your car probably has factory RKE. 95WhitePrix 1 Quote
95WhitePrix Posted January 21, 2020 Author Report Posted January 21, 2020 I didn't see a wire hanging down, and I didn't see the code for remote keyless entry on the sticker of options installed on it. Quote
digitaloutsider Posted January 21, 2020 Report Posted January 21, 2020 Guess you don't have it after all. There generally isn't a lot involved in installing a basic keyless lock/unlock system. However, if you don't feel comfortable doing it yourself, I can't imagine that an install shop would want much to do it. 95WhitePrix 1 Quote
95WhitePrix Posted January 21, 2020 Author Report Posted January 21, 2020 If I knew exactly what wires to hook it up to I could probably do it, but I wasn't able to find out much about it. Quote
digitaloutsider Posted January 21, 2020 Report Posted January 21, 2020 It's going to depend on which keyless system you go with. They're all a little different. Some can actuate the locks directly with a built in relay, some can't. Try to find the install guide for an aftermarket system and see if it's something you're willing to take on. Quote
