TRW Keyless Entry module
Sorry for digging up a old topic.. Am I understanding correctly that if the grounding terminal is in the trunk, than the car has RKE?
Also, my power locks dont seem to be working at all, is there a place I should start on this.
I might have owned a W previously, but that was a long time ago....
Yeah, if there is a lead hanging back by the antenna or somewhere in that general area, the car should have RKE.
Non-working locks could be something as basic as a fuse, so I'd just start there.
Where is the fuse located because my power looks work on my 92 GTP but can’t get it to go into programming mode and it has the correct RPO code.
If the locks work, it's not the fuse. If it won't go into programming mode when you ground the lead in the trunk, the box itself is screwed and needs to be resoldered.
Awesome I appreciate it. Now to find someone to fix it cause I can’t solder to save my life.
  • Like 1
The solder points on the box aren't small or intricate or anything, you could definitely do it yourself with a low cost iron. Good learning project.
Pulled the power lock fuse out, and all the interior light went out, put the fuse back in, and the locks started working.. WTF?
Went and ground the wire in the trunk, and nothing... Well I guess I wont be fixing that.. But I do have power locks!
I just wanted to second this. Earlier in this thread I said my keyless entry module was acting erratically in programming mode. I resoldered all the solder joints on both boards in the module and now it works great, both in my vehicle and on my test bench. The only annoying part is the conformal coating. It makes the iron want to slip off the solder joints. But you can still resolder through it without going through the trouble of trying to remove the coating. Just have to be careful as you're holding the iron.
If the module is acting up I would definitely recommend trying this. Add a little bit of new fresh solder to each joint as you do it.
  • 1 year later...
On 12/12/2019 at 7:19 PM, Quaraxkad said:
1994 gmc Jimmy 4 door  key fob reprogram
  • 2 years later...
On 12/12/2019 at 6:27 PM, ron350 said:
Does your TRW module box have a part # on it?
What is the location of this REMOTE KEYLESS ENTRY CONTROL MODULE  10063538 OEM for a 1994 Oldsmobile Cutlass Supreme & is this even the correct part#? I've been told in the trunk, back seat right side & under the dash for this part.
If it's the same as the 92, it's behind the rear passenger seat, under the trim panel.
  • 3 weeks later...
I just did this job and I relocated the module in the trunk. It's now velcroed on the inner fenderwell. There is plenty of wiring and the module can be hidden under the trunk carpet. Now when the next time it fails it will be a 10 minute job instead of a real headache
  • 10 months later...
Sorry to dig this topic up but I’m currently doing this job off and on on my 1991 Grand Prix. I have unbolted and taken out the back seat completely but haven’t found the module yet. Are they located in the same place on a 91 Grand Prix?
Is it a coupe? In my Regal, it’s behind the passenger side rear interior panel. I believe all of the 1st gen coupes, save for the convertibles have them in a similar location.
It’s roughly behind the red circle. IMG_0175.jpeg.76dcf487d605589430d96c22796a3516.jpeg
  • Like 1
  • Thanks 1
I could be wrong this was a long time ago. In my 1991 Grand prix my keyless entry did not work at all. Figured out the relay was getting power but not doing anything. If I recall it is under the rear package tray? I remember getting in the trunk at one point, but that could have been my convertible.
I did also remove my rear interior panels, but can't remember if it was for the keyless entry module.
Once you find it, just open it up and look for bad solder joints and touch them up. That's how I fixed mine.
In the GP it's mounted to the topside of the right rear parcel shelf next to the speaker.
  • Like 1
