mybluecutty Posted September 11, 2019 Report Posted September 11, 2019 I have a rt qtr window that is stuck down. Any ideas on how to fix short of drilling all the rivets out? Quote
MemphisMan Posted September 14, 2019 Report Posted September 14, 2019 On 9/11/2019 at 4:43 PM, mybluecutty said: I have a rt qtr window that is stuck down. Any ideas on how to fix short of drilling all the rivets out? For some reason the window motor gets stuck sometimes. Remove the rear interior trim panel so you can see the motor, then tap the motor with a hammer while pressing the switch up. Should free it up. It's a common issue. Quote
John M Posted September 23, 2019 Report Posted September 23, 2019 If I remember right I removed the ash tray put a prybar on motor and tapped. It does not take much. Quote
