Z34 lighting question
Hello Guys, I just bought a 93 Lumina Z34 and wondering if the A/C Heat panel along with the Automatic gear shift lights up/Backlit at night?
They should.  Not because it's night, but because you've turned the lights on.
The answer is yes, now the good news/bad news
the gear shift you can just pop it out or pull the console insert out and reach up and twist out the lamp and replace it
the HVAC you need to dissemble the entire thing and find suitable replacement bulbs and de-solder and re-solder in new ones
I'd double-check the lighting fuse(s) and the headlight dimmer switch first.
