jiggity76 Posted April 17, 2019 Report Posted April 17, 2019 Hey guys, I have the front exhaust manifold loose and ready to pull off but not sure how to get the crossover exhaust pipe that lays on top of the tranny loose to pull the manifold off. Is there any brackets along the side or underside of it that I have to unbolt? Or do I need to loosen the bolts that go into the rear manifold instead? Can't really see too well down in this area so not sure if there is any brackets or bolts on the crossover pipe. Thank you. Quote
jiggity76 Posted April 17, 2019 Author Report Posted April 17, 2019 Thanks to 55trucker, I loosened the three rear manifold bolts just enough to wiggle the crossover pipe away from the front manifold. Worked really well and everything is repaired and put back together. Thanks 55! Quote
