2000impala Posted April 6, 2019 Report Posted April 6, 2019 I have a 3500 that I have in my 2000 impala What do I need to do to crank and run Quote
Psych0matt Posted April 6, 2019 Report Posted April 6, 2019 He needs to do a key? That’s not right... Quote
Imp558 Posted April 6, 2019 Report Posted April 6, 2019 Perhaps a few more detailed description of the problem, assuming there's already a key involved. Nas Escobar 1 Quote
2000impala Posted April 6, 2019 Author Report Posted April 6, 2019 The key is not the issue I put a 3.5 in a 2000 impala 3.4 car I swapped parts off the 3.4 to the 3.5 everything upper and lower intake manifolds ,fuel rail and injectors , and all the sensors and the 3.5 just backfires Quote
2000impala Posted April 6, 2019 Author Report Posted April 6, 2019 The key is not the issue I put a 3.5 in a 2000 impala 3.4 car I swapped parts off the 3.4 to the 3.5 everything upper and lower intake manifolds ,fuel rail and injectors , and all the sensors and the 3.5 just backfires the 3.5 is a 04 05 year model out of a saturn relay van Quote
walterdude Posted April 6, 2019 Report Posted April 6, 2019 I could be wrong,,, but I seem to remember something about a 3500 swap needing an external crank trigger in order to run... It bolts to the crankshaft pulley... WOT Tech used to sell them... British Car Conversions sells them also... https://www.britishcarconversions.com/shop/trigger-kit-with-balancor If I recalled incorrectly,,, SORRY!!! I DO think that's right tho,,, Good Luck,,, Tom B... Quote
Imp558 Posted April 6, 2019 Report Posted April 6, 2019 I'm guessing a pcm that's very confused is the problem. Psych0matt 1 Quote
2000impala Posted April 6, 2019 Author Report Posted April 6, 2019 Will the pcm out of the saturn relay van work in the 2000 impala or should I get the engine harness to go with it Quote
Imp558 Posted April 7, 2019 Report Posted April 7, 2019 That's an incredibly complicated question. Quote
walterdude Posted April 7, 2019 Report Posted April 7, 2019 (edited) http://www.milzymotorsports.com/3500-swap/ Scroll down to..... How do you do a 3500 Swap into a 3100 or 3400-powered vehicle? The first Item pertains to the external trigger... Here is another swap guide... http://www.60degreev6.com/vb5/forum/pushrod-engines/pushrod-performance/12077-3500-swap-questions Tom B... Edited April 7, 2019 by walterdude Quote
2000impala Posted April 7, 2019 Author Report Posted April 7, 2019 Thank you I'm understanding this fix it's simple I sure don't want to mess this 3.5 engine up its a great running engine now I need to sale these 3.4 engines and parts 3.5 top parts to finish getting the money up to purchase the trigger kit Quote
Psych0matt Posted April 7, 2019 Report Posted April 7, 2019 Ok well thanks for the help No ones trying to be a dick but “muh car won’t start halp!” Isn’t much to go with. Hope you get it sorted! [emoji106] Nas Escobar 1 Quote
