Leadfoot Posted January 23, 2019 Report Posted January 23, 2019 I know this is a common issue, but I haven't owned a 3800 and dealt with it before. I did a search and couldn't come up with a thread showing proper repair process, but I know its a common issue. I must be using the wrong terms. I am in charge of an estate. There is a 03 Lesabre with the 3800 that has low miles. I have a niece that is 17 and needs a relaible cheap car. I was giving it a once over and getting it ready to pass inspection (it sat for over a year). Everything seems good to go and ready for inspection, but I checked for this leak knowing it was common and did find that it leaks slightly. On a google search I found a variety of opinions concerning the proper repair, but I have no idea how knowledgeable those people are. Everything from replace the o ring and quick connect at that connection to replacing the entire line. It appears Oreilly carries the ACDelco 217-452 orings. Is that all that is needed or is there something else that should be addressed. I just want to make sure its fixed for my niece. Quote
digitaloutsider Posted January 23, 2019 Report Posted January 23, 2019 Replacing the O-rings should be fine, unless someone REALLY mangled the fuel lines and quick connects somehow. Leadfoot 1 Quote
Imp558 Posted January 23, 2019 Report Posted January 23, 2019 The GM solution was to remove the dress cover so the fuel would evaporate more quickly. I like changing the o-rings and fixing the fucking leak a lot more. Leadfoot and digitaloutsider 2 Quote
Leadfoot Posted January 24, 2019 Author Report Posted January 24, 2019 11 hours ago, digitaloutsider said: Replacing the O-rings should be fine, unless someone REALLY mangled the fuel lines and quick connects somehow. No, its never been touched. Just leaks a little. 10 hours ago, Imp558 said: The GM solution was to remove the dress cover so the fuel would evaporate more quickly. I like changing the o-rings and fixing the fucking leak a lot more. HAHA I am not surprised. I agree. I don't want to be up at night worrying about my niece. I have done some things with $ out of my own pocket and not charging more. I just want it to be solid and not have to worry about it. Quote
FordMan77 Posted January 24, 2019 Report Posted January 24, 2019 Had this issue on my 00 GT and my brothers 01 GT. I followed the procedure below and haven't burnt one down yet, and I replaced mine probably 2-3 years ago now. Just take your time getting the plastic retainers out that separate the O-rings. It can be frustrating and you don't want to bend the nylon line around too hard. I just kinda layed on top of the motor so I could see under it to minimize the height I had to pull the lines up to. http://www.grandprixforums.com/general-tech-discussion/30008-could-this-be-causing-all-of-the-engine-fires.html?highlight=fires Leadfoot 1 Quote
ron350 Posted January 24, 2019 Report Posted January 24, 2019 Here is some information about replacing the fuel line o-rings. The same information should be on this forum but I can’t find it. https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3984252/1 There is lots of confusing and bad information in these threads about replacing the o-rings. There is no reason to remove the o-ring spacer inside the plastic fuel line fitting. You don’t what to use any kind of lubricant when removing and replacing the o-rings. GM used two #12 Viton o-rings in the larger supply line fittings and two #11 Viton o-rings in the smaller return fuel line fittings. Don’t be confused about the o-ring colors if the replacement o-ring is Black and the package says For Fuel Lines they will be Viton (Fluorcarbon). Don’t let some one talk you into using any other kind of o-ring material only use Viton (Fluorcarbon) o-rings. Nitrile and HNBR o-rings are not made for today’s gasoline so don’t use them unless you like fuel leaks. Quote
