RedZMonte Posted November 7, 2002 Report Posted November 7, 2002 i was curious if anyone knew if i could build a exhasut system on my 1992 Lumina Z34 converting it to single and then take it to a 1994 Regal and bolt it directly in. Does anyone know how simmilar the 2 exhaust systems are. I am hoping it will be like the Monte carlo LS/Z34 and just have everything interchange. My buddy with a 1994 regal is willing to bring the car down one day but it won't be untill the end of the month. I am going to try and compare the 2 today at my lunch brake. Tom: I know you have both cars, have you ever compared the two? I don't have pics on my server yet. but if anyone wants a pic of the midpipe i can e-mail it to you if you post your Addy. Shane Quote
SuperBuick Posted November 7, 2002 Report Posted November 7, 2002 Shane, the exhaust systems are nearly identical with the exception of the y-pipe into duals on the Z34. I will look later this afternoon, but I think the systems on both cars go OVER the rear spring/suspension. I know for a fact that it does on my regal. They also both bolt up/hang in the same place, again though the regal only on the passenger side and the Z34 on both. I never looked at where they meet the downpipe, but I assume it is the same. The cats and resonator are in the same place as well. I will look later to see if the bend in the regal system is where the y-pipe is on the Z34. -Tom Quote
GnatGoSplat Posted November 7, 2002 Report Posted November 7, 2002 On a 94, the Y is UNDER the rear axle. Quote
SuperBuick Posted November 7, 2002 Report Posted November 7, 2002 yeah but regals don't have a Y..... is the bend under the axle then? Quote
GnatGoSplat Posted November 7, 2002 Report Posted November 7, 2002 I have no idea on a Regal! Did they even have dual exhaust? Quote
SuperBuick Posted November 7, 2002 Report Posted November 7, 2002 nope they only had single on the passenger side. And you call yourself a W-Body guy!!!!!! Quote
GnatGoSplat Posted November 7, 2002 Report Posted November 7, 2002 Heheh! I haven't taken a look at too many Regals, they're the least common of all W-bodies. I didn't think I'd ever seen one with dual exhaust, but some of those early GS coupes with ground-effects certainly looked mean enough to have it. Unfortunately, I don't see those hardly ever. Mostly base model Regals or 4-drs around here. Quote
SuperBuick Posted November 7, 2002 Report Posted November 7, 2002 Same here, it is very uncommon to see an 88-92 GS. Thay had a single exhaust with dual tips. -Tom Quote
Lee Posted November 8, 2002 Report Posted November 8, 2002 It can be done. Mine was a single over the suspension 2". Now it's a dual 2.25 under the suspension. When I get home tonight I can post a bigger pic so you can see the y. Basicly we just bent a 94 dual GP exhaust. But bolted a new hanger where the center jack stand was. Didn't plan on it but it was there. Oh yeah...you can see it a bit bigger on my meger web site. Quote
RedZMonte Posted November 8, 2002 Author Report Posted November 8, 2002 I am planning on making 2 options for the regals: "2.25 mandrel bent Catback piping w/o muffler" and "2.25 mandrel bent Catback piping w/ Magnaflow Muffler no tip" I am designing the muffler with a 4x9" 2.25" offset inlet/center outlet Magnaflow muffler. But i might switch that to a center in dual out and run a muffler like this one, because it includes tips and it would be a good deal for $140. the dual oval tips i think would look good on the Regals: http://www.exhaustproslinc.com/mag5x8wduald.html I may add a tip so its a complete system. but as for install you will need to get your stock hangers welded to the new pip because the 1st gen w-bodies used some ghetto ass hangers that bolted to the hanger to the exhaust. and you will need to weld your stock catback flange to the new pipe. I think i will have it all flange together and have the muffler flanged as well so it can be unbolted and swaped. RedZ Quote
