snippits Posted November 14, 2018 Report Posted November 14, 2018 What is the equivalent of the tool J35689A to remove the terminals from the connector on the turn signal switch? Quote
Imp558 Posted November 15, 2018 Report Posted November 15, 2018 I use a safety pin or very small pick on little stuff like that. Bigger things can use a mechanic's pick. https://www.w-body.com/topic/56222-how-to-pcm-and-tranny-pin-thread/ Quote
snippits Posted November 15, 2018 Author Report Posted November 15, 2018 I already had a safety pin on standby! I read your thread, and thanks for all the information. Lisle 14900 GM terminal tool might work, but it looks to be awkward to use. https://www.lislecorp.com/specialty-tools/terminal-tool-for-gm Quote
Imp558 Posted November 15, 2018 Report Posted November 15, 2018 And it looks more expensive than ..... a readily available safety pin. I had the Delphi tool at one time, the pin was hardened and it broke after a couple uses. All the Delphi extractors are fragile but the Snap-on ones are a pretty good investment if you think you'll use them enough. I still reach for a safety pin first for everything except my 12014012-1 tool for the gunbarrel connectors and a piece of GM plastic vacuum line will work on those in a pinch. Quote
