WHERE DO THEY CONNECT?
That red wire it not connected to anything. It just hangs there and used for testing and bypassing the fuse/relay to test the fuel pump.
I don't see which hose you are talking about since the picture is so small.
BTW, what kind of car is it? If possible include your car model specs on your sig.
In picture #40.jpg, is that hooked up to the transmission?
It's hard to tell due to so small of a pic, but it look like just a breather tube.
Your brakes are working correctly? Any hissing (vacuum leak) or any symptoms?
- Erik
Guest Anonymous
That hose goes to the evap. solenoid. It is located on the back of the plenum, down a couple inches.
