Ignition switch replacement
On my 95 GP I believe the ignition switch is going bad. Sometimes when I turn the key it won't start the engine. Can hear the starter ingage, lights all work, radio works but sometimes it won't start. After a few attempt it starts right up.
Has anyone ever changed one on a 95-96 and is it something I can do or do I need specialty tools? Maybe need a mechanic to replace it?
Thanks
Sent from my SM-G900V using Tapatalk
If you hear the starter engage, the switch is doing it's job.  You have a starter problem, or a battery/wire harness problem.
For the record, there's a huge difference between "won't crank" and "cranks, but won't start".  You aren't clear about which is happening.
Edited by Schurkey
Sometimes it won't crank and then I will try again and its fine. When it does crank it fires right up without any problems. It's been intermittent really. Just started doing this last week, but it's not everytime I start the car. It's weird
Yep, if the solenoid clicks you probably have a bad starter.
Really be a good idea to inspect the engine grounds and battery cables before condemning the starter though.
I just replaced the starter not long ago. Not so sure that's the issue. I'll check the wires
Did you replace the starter with a new unit or a another used item?
It was a GM starter. GM reman I believe
A loose or corroded battery terminal can cause weird stuff. Clean and tighten your battery terminals, if issue still occurs, clean your ground points. Also check the date on your battery. If it's too old, it could cause issues. Then drive to a parts store and have them test the battery, and the charging system. Rule these simple things out first, then proceed to the starter, and ignition switch.
One can rule out the starter itself by testing it *still in the car* by using a remote starter switch, one lead directly to the positive side of the battery, the second lead goes to the ign terminal on the starter. Repeatedly press the button, if the starter responds in a normal manner all the time then start looking upstream for your issue. Disconnect the fuel pump relay when you perform this test.
http://i.ebayimg.com/images/i/371310437355-0-1/s-l1000.jpg
