luckybob Posted July 11, 2018 Report Posted July 11, 2018 Hey Everybody, I have a 1998 Grand Prix GTP 2 door. It has the performance shift button, but when I push it nothing happens. Every once in a while the performance shift light comes on without me touching the button. Has anyone ever had this problem? Is there a solenoid or some kind of wiring that could be the problem? Quote
jman093 Posted July 11, 2018 Report Posted July 11, 2018 I'm betting the wiring is broken. Pull up the shifter boot and inspect, and if that looks ok, pull up the top of the console and inspect. I bet you will find an issue. 94 olds vert and digitaloutsider 2 Quote
Grandprix1 Posted July 11, 2018 Report Posted July 11, 2018 The ground most likely came loose it should be in the center console someplace. 94 olds vert 1 Quote
94 olds vert Posted July 11, 2018 Report Posted July 11, 2018 I had an issue with mine. The ground wire rubs on the shifter and over time it breaks. It is s really easy fix once you pull that piece of plastic to access it. Quote
