crazyd Posted July 11, 2018 Report Posted July 11, 2018 When I did the '96 front brake upgrade out of a Lumina, I also got the soft and pillowy, worn-out oil struts from the car I took them from. Since my originals were so old I scrapped them along with a few thousand more pounds of metal recycle. Now it's time to pay the piper and put new gas struts in. I got a set of AC Delco gas struts and was reviewing the service manual, which says these can be done without taking the strut assembly out of the car and without using spring compressors. BUT - some special tools are required. I've done struts the usual way with a strut-compressor before. Has anyone ever done it this way before on a 1st-gen? It looks like you just pull the strut plates (or STB in my case), unscrew it and it lifts out the top, no fuss no.... well, a little muss, it says to remove the oil. Not sure what that's about. Can the tools from a standard loaner-tool complement at Autozone/O'Reillys be used for this process? Tools are: J35668 Strut Extension RodJ35669 Strut Rod Nut Remover & Installer J35671 Strut Cap Nut Wrench J38844 Strut Alignment Tool Quote
Imp558 Posted July 11, 2018 Report Posted July 11, 2018 I have the tool for sale in the classified section Quote
walterdude Posted July 11, 2018 Report Posted July 11, 2018 I can't find the strut tool anymore... I got one years ago at Advance, but, that one got trashed... It CAN be done without the tool tho... If you jack the car up, not enough to get the wheels off the ground tho... just enough to spread out the coils... If you lift up the bellows you can get a pipewrench on the nut that holds the strut into the lower portion of the strut tower... Of course you have to remove the stuff on the top of the tower first... Hope this helps,,, Tom B... Quote
jman093 Posted July 11, 2018 Report Posted July 11, 2018 It can be done without the tools. It just makes the job easier. 38844 I've always found useless. 35669 just removes the top shaft nut. Use it if you have it, but you should have little trouble getting this nut off with normal tools. 35668 threads onto the shaft can be useful for holding the assembly up straight while working, because the spring will want to cock it to the side once the rubber mount piece is pulled out. but it doesn't work on most replacement cartridges because they have the wrong thread pitch. Aftermarket doesn't give a shit. Pry bars will get the job done. 35671 removes the nut that holds the cartridge in the body. Very useful, but perhaps a pipe wrench or something would work as well. Yeah, suck all the old oil out once the old cartridge is removed. The new cartridge will blow new oil out by design once it starts getting used if it's factory style. Aftermarket ones may not do this, but won't need oil anyways. Quote
Imp558 Posted July 11, 2018 Report Posted July 11, 2018 I thought we were supposed to put a little oil in there. Alldata saya to. Quote
GTP091 Posted July 13, 2018 Report Posted July 13, 2018 The special tool you would need is # 7 and what looks like the extension for it #5. Would be nice if your autozone place had these as it is a fine thread and 35 years of road grime have probably corroded the threads up. It was a tough turn to get mine off and the spring was removed and strut assembly off the vehicle. You could use the spring compressor in reverse to widen the spring to get a pipe wrench in there better as the others have suggested. This will take you about 5-6 beers to complete. Go4DaMo 1 Quote
walterdude Posted July 13, 2018 Report Posted July 13, 2018 Sadly I had been sober for a number of years when I did that!!! Tom B... Quote
crazyd Posted July 17, 2018 Author Report Posted July 17, 2018 Well I ended up taking the whole thing out of the car on the right side, by accident. I was doing a whole bunch of things over there (brake pads, rotor, axle, axle bearing) in addition to the strut work, and I had mistakenly undone the top nut. Once I had it all apart I couldn't get it back together again. The parts-store loaner spring compressors are incapable of compressing a W spring adequately to install a replacement strut - and everything just gets in the way, the strut tower, the perch, the top plate - that I threw in the towel and took it to the pros. I had enough on my plate with the other four projects on that side alone. I still have to do the left side strut. I totally see the use for the J35668 extension rod, and wish I had one. Totally agree that J35669 isn't necessary with a high-power impact gun. And the replacement ACDelco units I got don't have the torx center but simple flats and extended top so you can fit an open-end wrench on it instead. I haven't tried loosening the cap nut without J35671 yet but I got a monster 14" pipe wrench on sale at Harbor Freight that should do it. Quote
Imp558 Posted July 17, 2018 Report Posted July 17, 2018 It's like an 8" pipe wrench to fit in there. It's not terrible to turn but you may have too much wrench in there to fit. Quote
crazyd Posted July 17, 2018 Author Report Posted July 17, 2018 HA! I have a 10" and I can't get the jaws open far enough even for half the size of it. The 14" pipe wrench I thought I got is actually an 18". If I can't get the left side with that it's coming out and going to the strut shop. Quote
mfewtrail Posted July 17, 2018 Report Posted July 17, 2018 (edited) These should work fine to compress your spring if you want to own a set: https://www.amazon.com/Lisle-62300-MacPherson-Strut-Tool/dp/B000COA1F8 You can't really make these any cheaper than that price. Normally they're around $50ish. They're safer than those cheap ones that just hook part of the coil. Lube the threads if you're going to use an impact wrench. Besides those, there's also a style that uses safety pins that. I believe the Lisle set is currently cheaper though. Edited July 17, 2018 by mfewtrail Quote
Imp558 Posted July 17, 2018 Report Posted July 17, 2018 HA! I have a 10" and I can't get the jaws open far enough even for half the size of it. The 14" pipe wrench I thought I got is actually an 18". If I can't get the left side with that it's coming out and going to the strut shop. You're right, I just looked at my 8 and it's a 10. With it all the way open I believe it fit. My next one is a 14 and I remember not having room to maneuver it so it must have been my 10. For a long time I had a set of whale jaw vise grips that opened up enough but it sucks having to reposition them every 1/4 turn or so. It should only take an hour or less to do a strut, maybe more the first time. Quote
Go4DaMo Posted August 29, 2018 Report Posted August 29, 2018 Useful thread! My cartridges are original in my 1st Gen Lumina Z34. What would w-body gurus recommend as a factory or better replacement? I am getting new tires and a 4-wheel alignment next Friday. I infer replacing front strut cartridges will not affect my alignment. Is this accurate? Yall are the best!Sent from my SM-G950U using Tapatalk Quote
GTP091 Posted September 1, 2018 Report Posted September 1, 2018 KYB is what most run. There’s not much in the way of anything better i think. Koni used to have adjustable rate shocks but I don’t think they’re made for us anymore. I could be wrong though. Quote
Imp558 Posted September 2, 2018 Report Posted September 2, 2018 I really liked my Gabriel Ultra struts, some don't. They're not performance minded but a little firmer than stock. The price is good and they have a legit lifetime warranty that I actually used on one years after the purchase. Quote
95GS Posted October 3, 2018 Report Posted October 3, 2018 On 7/11/2018 at 10:28 AM, Imp558 said: I thought we were supposed to put a little oil in there. Alldata saya to. I had heard/read that the oil served to cool the shock absorber. Quote
Imp558 Posted October 3, 2018 Report Posted October 3, 2018 I'm not sure if I believe that, it makes more sense that it keeps it from clattering around. In theory the oil could help transfer heat I guess. Quote
walterdude Posted October 3, 2018 Report Posted October 3, 2018 Not really sure what the oil does... Most things I've read say to get rid of it.. On my 99 water had gotten in there and made a pretty good (BAD) mess... Since then I've always run them dry,,,, with NO ill effects... NIGHT- NIGHT,,, Tom B...... Quote
55trucker Posted October 3, 2018 Report Posted October 3, 2018 10 hours ago, 95GS said: I had heard/read that the oil served to cool the shock absorber. The nitrogen charge inside the shock (that pressure one feels working against you when trying to compress the shock) is what keeps the shock cool when it's working. Any leftover oil inside the strut housing *should* be sucked out at the time the cartridge is replaced. Quote
Imp558 Posted October 3, 2018 Report Posted October 3, 2018 On Wednesday, July 11, 2018 at 10:28 AM, Imp558 said: I thought we were supposed to put manufacturerse oil in there. Alldata saya to. Damnit! I just looked again and Alldata says to remove it. It must have been on a strut manufacturers instructions. I distinctly remember reading "pour XX CC's of oil in tube prior to installation" and thinking what type of oil to use and how to measure it. I didn't want to remove the oil that was there so I just estimated (even before common core math I might add) and put jack oil in. Maybe that manufacturer wanted to prevent rust or slop? If the tube is supposed to be empty why didn't the GM Gods just put a weep hole in? Quote
55trucker Posted October 3, 2018 Report Posted October 3, 2018 2 hours ago, Imp558 said: Damnit! UH-OH, I sense one of these coming on.... Quote
95GS Posted October 4, 2018 Report Posted October 4, 2018 9 hours ago, Imp558 said: Damnit! If it's any consolation, I have oil in one side, the other is dry. Quote
jman093 Posted October 14, 2018 Report Posted October 14, 2018 On 10/3/2018 at 1:41 PM, Imp558 said: Damnit! I just looked again and Alldata says to remove it. It must have been on a strut manufacturers instructions. I distinctly remember reading "pour XX CC's of oil in tube prior to installation" and thinking what type of oil to use and how to measure it. I didn't want to remove the oil that was there so I just estimated (even before common core math I might add) and put jack oil in. Maybe that manufacturer wanted to prevent rust or slop? If the tube is supposed to be empty why didn't the GM Gods just put a weep hole in? There should be oil in there. As I said in an above post. You are supposed to suck it all out and the factory style cartridges from GM blew out some new oil the first time they were used and refilling the housing. I don't think any aftermarket ones use the oil though. I think they are normal sealed shocks and should be run dry. Either way suck the oil out before installation. Those original GM ones that ran in their oil bath were different looking things. Quote
Imp558 Posted October 14, 2018 Report Posted October 14, 2018 I still say keep the oil. It's not a stretch to imagine the oil facilitating heat transfer to help keep the shock cool for one. Also a little oil will keep the cartridge from getting rusted into the tube and keep the tube from rusting. It's really no more harmful than oil undercoating. I get that it doesn't need to be there but I'm not buying that it can't be there. Quote
