Brodizzle83 Posted June 20, 2018 Report Posted June 20, 2018 Saw one of these in a '94-96 GTP and wonder if they could be used accurately in an SE with a 3100? Sent from my SM-G955U using Tapatalk Quote
94 olds vert Posted June 20, 2018 Report Posted June 20, 2018 A 1996 DIC is rare. Those units are OBD II. While 94 and 94 DIC are OBD 1.5. A DIC from a 94 or 95 GTP will function in just about any OBD 1.5 vehicle if it is wired properly. Quote
jiggity76 Posted June 20, 2018 Report Posted June 20, 2018 I've found some in 1996 cars but they are complete cars, not junkyard ones so might be hard to find more of them. There was that one car down at the Des Moines Wrench N Go that I might have been a 96 GTP, black car that looked like it hit a telephone pole going sideways, could have been a 95 car. It had DIC and now I wished I would have pulled the DIC if it was a 96 car. Can't find the pic, I'll have to look later tonite. Quote
jman093 Posted July 2, 2018 Report Posted July 2, 2018 Yes, you can swap them. I did this on my brother's 96 GP SE. The engine does not matter. The DIC is the same. As mentioned, the year is what you need to look out for. 94-95 needs a DIC from a 94-95 car. 96 needs a DIC from a 96 car. The connectors are most likely already present behind the cluster bezel. It's simple plug and play, except for the outside air temp. To make that work, you would need to take the temp sensor off the front of the car and wire it into the DIC. Quote
Imp558 Posted July 2, 2018 Report Posted July 2, 2018 I ran an OBD1 DIC to my first meet. The 96-97 PCMs have both class II and uart serial data. Naturally it wasn't plugged into the factory harness and it sat atop the dash, but I knew what my fuel economy was the whole way. Quote
Imp558 Posted July 2, 2018 Report Posted July 2, 2018 Oh, that's a left hand DIC too, don't see them every day. Quote
