95LQ1VERT Posted March 30, 2020 Author Report Posted March 30, 2020 Finally got around to retrofitting 4th gen Camaro window sweep felts on my Cutlass. It definitely looks much better, and the wind noise reduced some! Hopefully they last a while considering they have been on a junkyard Camaro for its lifetime. Sent from my SM-N960U using Tapatalk GabsOlds and 94 olds vert 2 Quote
GabsOlds Posted March 30, 2020 Report Posted March 30, 2020 Congratulations on the upgrade. 95LQ1VERT 1 Quote
95LQ1VERT Posted April 20, 2020 Author Report Posted April 20, 2020 My idle issue is back... The idle likes to dip up and down when slowing down or coasting. It's not every time I slow down but intermittent and feels like it wants to stall. My old Actron Scanner shows no faults, no misfiring, and it has me stumped. I recently changed the injectors out cause 2 old ones were dripping fuel into the cylinders and it was causing an issue starting after it had ran for a bit. Now it runs smoother while accelerating or at idle but still acts like it wants to stall when coasting or coming to a stop.I checked the fuel pressure at the rail when I did the injectors, and at KOEO the pump only primed to 35psi. Engine running was around 32 psi, and when I unplugged the vac line off th FPR, it went up to 39psi. After I prime the pump and shut it off, the pressure dropped from 35psi to 0 in less than an hour. So the pump or check valve in the pump I believe is suspect?The only thing that hasn't been replaced on this car are the crankshaft sensors, the fuel pump, the alternator and the computer. I am stumped.Sent from my SM-N960U using Tapatalk Quote
95LQ1VERT Posted February 14, 2025 Author Report Posted February 14, 2025 Hi everyone! Little update... I still have the ol' Cutlass Convertible. Been through a tornado with it, barely touched thankfully, and its currently sitting in my barn at 119K miles. 94 olds vert and pwmin 2 Quote
bluecalais79 Posted February 14, 2025 Report Posted February 14, 2025 Intake manifold gaskets may need to be changed. Quote
