onehit Posted April 29, 2018 Report Posted April 29, 2018 I've got a 2002 GTP and Im having an issue with my low beams, the DRLs work, the highs work, but no lows I checked all the fuses and the bulbs. any other suggestions? Quote
GTP091 Posted April 30, 2018 Report Posted April 30, 2018 Switch?. If it was a wiring issue you may only lose one and if the DRLs work It would seem the wiring is not the issue. Could have a bad ground but I’d expect there be several grounds in the system. I’d test the switch, if it’s doable. Quote
55trucker Posted April 30, 2018 Report Posted April 30, 2018 I suspect that the multi-function switch has failed. Quote
Chev1988rolet Posted May 24, 2018 Report Posted May 24, 2018 Just saw its an 02, should be the multi switch. Test the relay for the low beams and see if u recieve ground when the switch is turned on Quote
