Brodizzle83 Posted April 19, 2018 Report Posted April 19, 2018 The wheels on the GP I'm looking to purchase have a really nasty gray film of something on the lips. It's mostly on the rear wheels. Has anyone resurfaced the lips on their GP crosslace wheels? If So, what was your technique? I've seen videos of putting the wheel on the drive axle and let it "drive" while on jackstands, then take sandpaper and go to town. Seems kinda dangerous... Sent from my SM-G955U using Tapatalk Quote
Imp558 Posted April 19, 2018 Report Posted April 19, 2018 It's epoxy paint, Lowes sells an epoxy paint remover. Buy rubber gloves at the same day, don't want that stuff on skin. I used nylon wire wheels from Harbor Freight after the epoxy paint remover to get the little stubborn spots. Quote
Addicted To Boost Posted April 19, 2018 Report Posted April 19, 2018 I've seen videos of putting the wheel on the drive axle and let it "drive" while on jackstands, then take sandpaper and go to town. Seems kinda dangerous... Sent from my SM-G955U using Tapatalk I used that method. Not ideal, but it worked well. You need to strip all the clear off the lips first. Make sure to tape off the lace portion well so the aircraft remover doesn't seep into the laces and eat the paint off. Quote
55trucker Posted April 19, 2018 Report Posted April 19, 2018 are you working with the gray wheels or the gold? gray are painted, gold are powdercoated, as stated both are clearcoated. again as stated stripper will remove all that isn't alloy. To clean up the lips use wet paper, I started with 600 & gradually worked up to 1500, then polished the lips by hand & with a buffer. My wheels are the gray, I glass beaded them first (the lip area & the center had to be protected from the blasting), cleaned up the lips then repainted the hub portion. That was done 14 years ago. Quote
Imp558 Posted April 19, 2018 Report Posted April 19, 2018 are you working with the gray wheels or the gold? gray are painted, gold are powdercoated, as stated both are clearcoated. again as stated stripper will remove all that isn't alloy. To clean up the lips use wet paper, I started with 600 & gradually worked up to 1500, then polished the lips by hand & with a buffer. My wheels are the gray, I glass beaded them first (the lip area & the center had to be protected from the blasting), cleaned up the lips then repainted the hub portion. That was done 14 years ago. Was that a metal center cap? Mine are plastic so the best I could do was paint them black. If there are Aluminum ones I'd like to know where to find them. Quote
jiggity76 Posted April 19, 2018 Report Posted April 19, 2018 are you working with the gray wheels or the gold? gray are painted, gold are powdercoated, as stated both are clearcoated. again as stated stripper will remove all that isn't alloy. To clean up the lips use wet paper, I started with 600 & gradually worked up to 1500, then polished the lips by hand & with a buffer. My wheels are the gray, I glass beaded them first (the lip area & the center had to be protected from the blasting), cleaned up the lips then repainted the hub portion. That was done 14 years ago. You did a great job! I assumed they were the white factory painted ones already. The car he's looking at has factory painted white crosslaces. Quote
55trucker Posted April 19, 2018 Report Posted April 19, 2018 The center cap is metal, the wheels came off a non-abs SE with the B4U package. Quote
55trucker Posted April 19, 2018 Report Posted April 19, 2018 You did a great job! I assumed they were the white factory painted ones already. The car he's looking at has factory painted white crosslaces. The crosslace wheels were never available in white (with the exception of the white Petty edition wheels which are slightly different in the way they are painted). If one comes across a set in white they've been repainted. Here's what the Petty wheels look like..........these are blue Quote
Imp558 Posted April 19, 2018 Report Posted April 19, 2018 The center cap is metal, the wheels came off a non-abs SE with the B4U package. Wow! Thank you Quote
jiggity76 Posted April 19, 2018 Report Posted April 19, 2018 The crosslace wheels were never available in white (with the exception of the white Petty edition wheels which are slightly different in the way they are painted). If one comes across a set in white they've been repainted. Here's what the Petty wheels look like..........these are blue I've seen the blue RPE ones but never the white ones (I knew about the white ones on the RPE cars just never seen one yet) and just assumed both your car and his potential car - the rims were swapped off of a RPE car. By the way, did you see his GTP 5 speed parts car? It's pretty cool. Quote
Brodizzle83 Posted April 19, 2018 Author Report Posted April 19, 2018 are you working with the gray wheels or the gold? gray are painted, gold are powdercoated, as stated both are clearcoated. again as stated stripper will remove all that isn't alloy. To clean up the lips use wet paper, I started with 600 & gradually worked up to 1500, then polished the lips by hand & with a buffer. My wheels are the gray, I glass beaded them first (the lip area & the center had to be protected from the blasting), cleaned up the lips then repainted the hub portion. That was done 14 years ago. These are the wheels. The lips look grey because they're coated in...I dunno...brake dust maybe? Sent from my SM-G955U using Tapatalk Quote
55trucker Posted April 19, 2018 Report Posted April 19, 2018 These are the wheels. The lips look grey because they're coated in...I dunno...brake dust maybe? Sent from my SM-G955U using Tapatalk That looks like general lack of care to me, if there were brake dust on the wheel the hub spokes would be covered in it. If the pads are metallic or carbon the dust is usually black in appearance, ceramic would be a brown haze. I'm constantly cleaning it off the fronts. Quote
