Brodizzle83 Posted April 15, 2018 Report Posted April 15, 2018 The 1992 GP I'm thinking of buying has a "low fuel" light that stays on. The guy fueled it up before I showed up to look at it and it said "check gauges" and the little orange light for low fuel was on. Is this a common problem? Sent from my SM-G955U using Tapatalk Quote
55trucker Posted April 15, 2018 Report Posted April 15, 2018 Oh my-o-my. I wonder what-in-the-world that could possibly be? your instrument cluster is suffering from a case of cold solder joint syndrome. it is a virus that can strike when you least expect it, tylenol & anti-inflammatories will not relieve it, the cure is an indepth cluster *resolder* Quote
94 olds vert Posted April 15, 2018 Report Posted April 15, 2018 I had the same issue with my 1991. Re-soldering the joints in the back of the cluster fixed the issue. Quote
Brodizzle83 Posted April 17, 2018 Author Report Posted April 17, 2018 Sweet, thank you so much! When I get the car, that's one of the first things I'm doing to it. Sent from my SM-G955U using Tapatalk Quote
GTP091 Posted April 17, 2018 Report Posted April 17, 2018 Use it as leverage to get a better deal! Quote
