transmission interchange 1991 regal gs
My car- a 91 regal gs coupe transmission with 220k bit the dust last month.  I was about to give it away to the junk yard but decided to get a used 4t60 and put it in.
When I searched car-part.com for used transmissions for 1991 they only are giving me the 1991 year. Was 91 an odd year?
I did find a 1992 regal gs transmission with 115k for 120 dollars but for some reason it does not interchange on car-part.
I thought 91 and 92 were the same.
Please help?
Thanks
  • 5 weeks later...
Somewhere along the line, the trans became electronically operated instead of vacuum operated. Hence the name change from 4T60 to 4T60E
Here's the interchange: I'm guessing it's a 3.8 being a GS though the GS was available with the 3.1. Consult a trans shop to make sure of these. These are from the Hollander Interchange which is what the junkyards use.
Q ----------
REGAL 90-91 A.T.; 6-231 (3.8L)
4 spd AT, T.H.440, 4T60, ME9
WARNING-When changing final drive ratio, include corresponding prom for ECM and change governor as necessary (or speedometer could be inaccurate).
|A| thru |U| fit as shown in notes.
Q -----------
5 Hole 4 Pin torque converter connector.
Shift shaft is 7mm longer than previous years.
|F| thru |H| & |M| fit, if equipped with the bosses & holes needed to mount the upper bracket, by transferring valve body wiring, switches & electrical connector.
|N| & |P| fit by transferring valve body wiring, switches & electrical connector as needed.
F ----------
6000 88-89 A.T.; TH440
BONNEVILLE 88 A.T., FWD; engine VIN (8th digit) "3"
CELEBRITY 88-89 A.T.; TH440
CENTURY 88-90 A.T.; TH440
CIERA 88-90 A.T.; TH440
EIGHTY EIGHT 88 A.T., FWD; engine VIN (8th digit) "3"
ELECTRA 88 A.T., FWD; engine VIN (8th digit) "3"
LESABRE 88 A.T., FWD; engine VIN (8th digit) "3"
NINETY EIGHT 88 A.T., FWD; engine VIN (8th digit) "3" (Canada)
PARK AVENUE 88 A.T., FWD; engine VIN (8th digit) "3"
RIVIERA 87 A.T.
TORONADO 87 A.T.
G ----------
6000 90-91 A.T.; TH440
BONNEVILLE 88 A.T., FWD; engine VIN (8th digit) "C"
BONNEVILLE 89-91 A.T., FWD
CELEBRITY 90 A.T.; TH440
EIGHTY EIGHT 88 A.T., FWD; engine VIN (8th digit) "C"
EIGHTY EIGHT 89-91 A.T., FWD
ELECTRA 88 A.T., FWD; engine VIN (8th digit) "C"
ELECTRA 89-90 A.T., FWD
LESABRE 88 A.T., FWD; engine VIN (8th digit) "C"
LESABRE 89-91 A.T., FWD
NINETY EIGHT 88 A.T., FWD; engine VIN (8th digit) "C"
NINETY EIGHT 89-90 A.T., FWD
PARK AVENUE 88 A.T., FWD; engine VIN (8th digit) "C"
PARK AVENUE 89-90 A.T., FWD
REATTA 88-90 A.T.
RIVIERA 88-90 A.T.
TORONADO 88-90 A.T.
H ----------
CENTURY 91-93 A.T.; TH440
CIERA 91-93 A.T.; TH440
M ----------
DEVILLE 88-90 A.T., FWD
ELDORADO 88-90 A.T.
FLEETWOOD 88-90 A.T., FWD
SEVILLE 88-90 A.T.
N ----------
CUTLASS 88 A.T.; TH440 (FWD)
CUTLASS 89 A.T.; (TH440), 6-173 (2.8L)
GRAND PRIX 88 A.T.
GRAND PRIX 89 A.T.; 6-173 (2.8L)
REGAL 88 A.T.
REGAL 89 A.T.; 6-173 (2.8L)
P ----------
CUTLASS 89 A.T.; (TH440), 6-191 (3.1L)
CUTLASS 90 A.T.; TH440 (4T60)
CUTLASS 91 A.T.; TH440 (4T60, 3.1L)
CUTLASS 92 A.T.; TH440 (4T60)
GRAND PRIX 89-90 A.T.; 6-191 (3.1L)
GRAND PRIX 91 A.T.; TH440 (4T60, 3.1L)
GRAND PRIX 92 A.T.; TH440 (4T60)
LUMINA CAR 90 A.T.; TH440 (4T60)
LUMINA CAR 91-92 A.T.; TH440 (4T60, 3.1L)
REGAL 89-91 A.T.; 6-191 (3.1L)
REGAL 92 A.T.
