ManicMechanic Posted March 24, 2018 Report Posted March 24, 2018 Okay, yes this is my Aztek but since the Ws came with the same trans I am going to ask here, you can move it if you like. I replaced the 4th clutch hub shaft, the clutch pack, thrust washers and all but it still will not go in to 4th. It acts like it wants to but goes back to 3rd. The TC locks up as it should, it seems. I don't have a Tech2 or anything like it to check to see if 4th is being commanded. Kind of at a loss and not sure if it's mechanical or electrical. Quote
Imp558 Posted March 24, 2018 Report Posted March 24, 2018 (edited) Any experience with electronics? There's only two shift solenoids, that means if you wire a REALLY simple circuit to them involving a couple LEDs and a couple resistors you can compare them with the truth table to see what gear is being commanded. I have the truth table. Shift Solenoid Patterns for each gear: Range 1-2 Solenoid 2-3 Solenoid Park ON ON Reverse ON ON Neutral ON ON 1st Gear ON ON 2nd Gear OFF ON 3rd Gear OFF OFF 4th Gear ON OFF Edited March 24, 2018 by Imp558 ManicMechanic and Galaxie500XL 2 Quote
wstefan20 Posted March 24, 2018 Report Posted March 24, 2018 I've seen some weird stuff with the valve body sticking and losing 4th, but always with other issues. Hate to say, I'm more of a fan of a full rebuild, though I know $h!t happens and sometimes you have to try Quote
wstefan20 Posted March 24, 2018 Report Posted March 24, 2018 Forgot to mention, I'm not terribly far from you, so if you want, I've got a core I could rebuild if you end up going that route. I know long down times stink. Good luck! Quote
jman093 Posted March 24, 2018 Report Posted March 24, 2018 You may not have a tech 2, but can you at least scan for codes? OBD2 GM cars are really good about setting relevant transmission related DTCs. Even 1996 4T60e cars have good diagnostics. If it's commanding 4th and not getting it, it should set a P1870 code pretty quick. There may also be codes in the PCM for failed shift solenoids and any number of malfunctions with or without a P1870. Start by scanning it. Quote
ManicMechanic Posted March 24, 2018 Author Report Posted March 24, 2018 You may not have a tech 2, but can you at least scan for codes? OBD2 GM cars are really good about setting relevant transmission related DTCs. Even 1996 4T60e cars have good diagnostics. If it's commanding 4th and not getting it, it should set a P1870 code pretty quick. There may also be codes in the PCM for failed shift solenoids and any number of malfunctions with or without a P1870. Start by scanning it. I do have a code reader, but no codes. I am not sure if it scans TCM codes or not. I did put in new solenoids because I had a harsh shift in to drive and 1-2, with new solenoids that is gone. Forgot to mention, I'm not terribly far from you, so if you want, I've got a core I could rebuild if you end up going that route. I know long down times stink. Good luck! Raytown is quite a ways from Austin, Tx. hah (strangely enough, I have another friend in Raytown, Jacob Tuck, has a blue 1977 Chevy longbed truck in beautiful condition.) I do appreciate the offer! Quote
ManicMechanic Posted March 24, 2018 Author Report Posted March 24, 2018 Any experience with electronics? There's only two shift solenoids, that means if you wire a REALLY simple circuit to them involving a couple LEDs and a couple resistors you can compare them with the truth table to see what gear is being commanded. I have the truth table. Shift Solenoid Patterns for each gear: Range 1-2 Solenoid 2-3 Solenoid Park ON ON Reverse ON ON Neutral ON ON 1st Gear ON ON 2nd Gear OFF ON 3rd Gear OFF OFF 4th Gear ON OFF I'm not too shabby with electronics so might have to give this one a try if I can. Quote
ManicMechanic Posted March 24, 2018 Author Report Posted March 24, 2018 Do you need transmission schematics? Negative, I have alldata. Imp558 1 Quote
