Missfire and ticking P0300
  On 2/18/2018 at 8:39 PM, 55trucker said:
You're mistaking the sound you're hearing at the rocker for being a faulty rocker. That's not the case, when the lifter collapses you won't hear a clattering at the lifter, you'll hear the clattering at the rocker arm where the arm contacts the valve stem. Since there is a lack of pressure there to keep the clearances tight the end of the rocker now has a gap between it & the valve stem & that's the clattering one hears.
I figured it was more of an issue of the rocker thread being stripped out but the noise seems to be coming from nearly every cylinder.
